Inserting camera model programmatically
I want to be able to record a simulation in Gazebo. For this I use a camera model, as discussed in this question.
The following camera model works fine if I insert it from the Gazebo GUI or if I include it in a .world file. (The model is taken from the above question, with the only notable difference that I moved <save> element into the <camera> element, which appears to be necessary):
<?xml version="1.0" ?>
<sdf version="1.5">
  <model name="camera">
    <pose>4 -4 4 0 0.5 2.4</pose>
        <mass>0.1</mass>
      <sensor name="camera" type="camera">
            <width>1280</width>
            <height>960</height>
            <far>100</far>
          <save enabled="true">
            <path>/tmp/gazebo_frames</path>
          </save>
        <update_rate>50</update_rate>
The problem
Now I want to be able to insert the model programmatically, when using Gazebo as a library.
I have created a minimum working example here: Pastebin
When I run this MWE I get a segmentation fault (after inserting the model, in the while loop where I wait for the model to show up). If I remove the element, inserting the model is successful.
What am I doing wrong?
Thanks for your help.
EDIT:
Below is the backtrace from running the MWE:
Starting program: /home/nicolas/GazeboAgentCameraExample/build/main
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7fffdd4c4700 (LWP 13481)]
[New Thread 0x7fffdccc3700 (LWP 13482)]
[New Thread 0x7fffdc4c2700 (LWP 13483)]
[New Thread 0x7fffdb3d3700 (LWP 13484)]
[New Thread 0x7fffd8dc4700 (LWP 13485)]
[New Thread 0x7fffd0a10700 (LWP 13486)]
[New Thread 0x7fffcbfff700 (LWP 13487)]
[New Thread 0x7fffcb7fe700 (LWP 13488)]
[New Thread 0x7fffcaffd700 (LWP 13489)]
Gazebo server setup successful
[New Thread 0x7fffca3c4700 (LWP 13490)]
[New Thread 0x7fffc9bc2700 (LWP 13492)]
[New Thread 0x7fffc9fc3700 (LWP 13491)]
[New Thread 0x7fffc97c1700 (LWP 13493)]
[New Thread 0x7fffc8fc0700 (LWP 13495)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffc97c1700 (LWP 13493)]
0x00007ffff1f93fa9 in gazebo::sensors::SensorFactory::NewSensor(std::string const&) () from /usr/lib/x86_64-linux-gnu/libgazebo_sensors.so.4
(gdb) thread apply all bt
Thread 15 (Thread 0x7fffc8fc0700 (LWP 13495)):
#0  pthread_cond_wait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_wait.S:185
#1  0x00007ffff7b53efb in ?? () from /usr/lib/x86_64-linux-gnu/libgazebo_physics.so.4
#2  0x00007ffff7b4aec7 in gazebo::physics::World::LogWorker() () from /usr/lib/x86_64-linux-gnu/libgazebo_physics.so.4
#3  0x00007ffff4c45a4a in ?? () from /usr/lib/x86_64-linux-gnu/libboost_thread.so.1.54.0
#4  0x00007ffff7151182 in start_thread (arg=0x7fffc8fc0700) at pthread_create.c:312
#5  0x00007ffff6963efd in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 14 (Thread 0x7fffc97c1700 (LWP 13493)):
#0  0x00007ffff1f93fa9 in gazebo::sensors::SensorFactory::NewSensor(std::string const&) () from /usr/lib/x86_64-linux-gnu/libgazebo_sensors.so.4
#1  0x00007ffff1f96e67 in gazebo::sensors::SensorManager::CreateSensor(boost::shared_ptr<sdf::Element>, std::string const&, std::string const&, unsigned int) ()
#2  0x00007ffff1f8e6ab in gazebo::sensors::create_sensor(boost::shared_ptr<sdf::Element>, std::string const&, std::string const&, unsigned int) () from /usr/lib/x86_64-linux-gnu/libgazebo_sensors.so.4
#3  0x00007ffff7b0d43b in gazebo::physics::Link::Load(boost::shared_ptr<sdf::Element>) () from /usr/lib/x86_64-linux-gnu/libgazebo_physics.so.4
#4  0x00007ffff63c9ec1 in gazebo::physics::ODELink::Load(boost::shared_ptr<sdf::Element>) () from /usr/lib/x86_64-linux-gnu/libgazebo_physics_ode.so.4
#5  0x00007ffff7b1df0b in gazebo::physics::Model::LoadLinks() () from /usr/lib/x86_64-linux-gnu/libgazebo_physics.so.4
#6  0x00007ffff7b20371 in gazebo::physics::Model::Load(boost::shared_ptr<sdf::Element>) () from /usr/lib/x86_64-linux-gnu/libgazebo_physics.so.4
#7  0x00007ffff7b4846c in gazebo::physics::World::LoadModel(boost::shared_ptr<sdf::Element>, boost::shared_ptr<gazebo::physics::Base>) () from /usr/lib/x86_64-linux-gnu/libgazebo_physics.so.4
#8  0x00007ffff7b4e792 in gazebo::physics::World::ProcessFactoryMsgs() () from /usr/lib/x86_64-linux-gnu/libgazebo_physics.so.4
#9  0x00007ffff7b4f614 in gazebo::physics::World::ProcessMessages() () from /usr/lib/x86_64-linux-gnu/libgazebo_physics.so.4
#10 0x00007ffff7b50850 in gazebo::physics::World::Step() () from /usr/lib/x86_64-linux-gnu/libgazebo_physics.so.4
#11 0x00007ffff7b50d45 in gazebo::physics::World::RunLoop() () from /usr/lib/x86_64-linux-gnu/libgazebo_physics.so.4
#12 0x00007ffff4c45a4a in ?? () from /usr/lib/x86_64-linux-gnu/libboost_thread.so.1.54.0
#13 0x00007ffff7151182 in start_thread (arg=0x7fffc97c1700) at pthread_create.c:312
#14 0x00007ffff6963efd in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 13 (Thread 0x7fffc9fc3700 (LWP 13491)):
#0  syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
#1  0x00007ffff1d0b2db in ?? () from /usr/lib/libtbb.so.2
#2  0x00007ffff1d0b2f9 in ?? () from /usr/lib/libtbb.so.2
#3  0x00007ffff7151182 in start_thread (arg=0x7fffc9fc3700) at pthread_create.c:312
#4  0x00007ffff6963efd in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 12 (Thread 0x7fffc9bc2700 (LWP 13492)):
#3  0x00007ffff7151182 in start_thread (arg=0x7fffc9bc2700) at pthread_create.c:312
Thread 11 (Thread 0x7fffca3c4700 (LWP 13490)):
#3  0x00007ffff7151182 in start_thread (arg=0x7fffca3c4700) at pthread_create.c:312
Thread 10 (Thread 0x7fffcaffd700 (LWP 13489)):
#1  0x00007fffea02d690 in ?? () from /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.8.1
#2  0x00007fffea02c6af in Ogre::DefaultWorkQueue::waitForNextRequest() () from /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.8.1
#3  0x00007fffea02cb24 in Ogre::DefaultWorkQueue::_threadMain() () from /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.8.1
#4  0x00007ffff4c45a4a in ?? () from /usr/lib/x86_64-linux-gnu/libboost_thread.so.1.54.0
#5  0x00007ffff7151182 in start_thread (arg=0x7fffcaffd700) at pthread_create.c:312
#6  0x00007ffff6963efd in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
---Type <return> to continue, or q <return> to quit---
Thread 9 (Thread 0x7fffcb7fe700 (LWP 13488)):
#5  0x00007ffff7151182 in start_thread (arg=0x7fffcb7fe700) at pthread_create.c:312
Thread 8 (Thread 0x7fffcbfff700 (LWP 13487)):
#5  0x00007ffff7151182 in start_thread (arg=0x7fffcbfff700) at pthread_create.c:312
Thread 7 (Thread 0x7fffd0a10700 (LWP 13486)):
#5  0x00007ffff7151182 in start_thread (arg=0x7fffd0a10700) at pthread_create.c:312
Thread 6 (Thread 0x7fffd8dc4700 (LWP 13485)):
#1  0x00007fffd9e42263 in ?? () from /usr/lib/x86_64-linux-gnu/dri/radeonsi_dri.so
#2  0x00007fffd9e41ba7 in ?? () from /usr/lib/x86_64-linux-gnu/dri/radeonsi_dri.so
#3  0x00007ffff7151182 in start_thread (arg=0x7fffd8dc4700) at pthread_create.c:312
Thread 5 (Thread 0x7fffdb3d3700 (LWP 13484)):
#0  pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_timedwait.S:238
#1  0x00007ffff5c1f5a0 in gazebo::transport::ConnectionManager::Run() () from /usr/lib/x86_64-linux-gnu/libgazebo_transport.so.4
#2  0x00007ffff4c45a4a in ?? () from /usr/lib/x86_64-linux-gnu/libboost_thread.so.1.54.0
#3  0x00007ffff7151182 in start_thread (arg=0x7fffdb3d3700) at pthread_create.c:312
Thread 4 (Thread 0x7fffdc4c2700 (LWP 13483)):
#0  __clock_nanosleep (clock_id=0, flags=0, req=0x7fffdc4c1d00, rem=0xffffffffffffffff) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:49
#1  0x00007ffff782ca83 in gazebo::common::Time::Sleep(gazebo::common::Time const&) () from /usr/lib/x86_64-linux-gnu/libgazebo_common.so.4
#2  0x00007ffff782cc47 in gazebo::common::Time::MSleep(unsigned int) () from /usr/lib/x86_64-linux-gnu/libgazebo_common.so.4
#3  0x00007ffff75937ed in gazebo::Master::Run() () from /usr/lib/x86_64-linux-gnu/libgazebo.so.4
#5  0x00007ffff7151182 in start_thread (arg=0x7fffdc4c2700) at pthread_create.c:312
Thread 3 (Thread 0x7fffdccc3700 (LWP 13482)):
#0  0x00007ffff6964593 in epoll_wait () at ../sysdeps/unix/syscall-template.S:81
#1  0x00007ffff5c113a8 in ?? () from /usr/lib/x86_64-linux-gnu/libgazebo_transport.so.4
#2  0x00007ffff5c157b1 in ?? () from /usr/lib/x86_64-linux-gnu/libgazebo_transport.so.4
#3  0x00007ffff5c24a86 in ?? () from /usr/lib/x86_64-linux-gnu/libgazebo_transport.so.4
#5  0x00007ffff7151182 in start_thread (arg=0x7fffdccc3700) at pthread_create.c:312
Thread 2 (Thread 0x7fffdd4c4700 (LWP 13481)):
#1  0x00007ffff781966b in ?? () from /usr/lib/x86_64-linux-gnu/libgazebo_common.so.4
#2  0x00007ffff7814566 in gazebo::common::ModelDatabase::UpdateModelCache(bool) () from /usr/lib/x86_64-linux-gnu/libgazebo_common.so.4
#4  0x00007ffff7151182 in start_thread (arg=0x7fffdd4c4700) at pthread_create.c:312
Thread 1 (Thread 0x7ffff7f8c880 (LWP 13477)):
#0  __clock_nanosleep (clock_id=0, flags=0, req=0x7fffffffddb0, rem=0xffffffffffffffff) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:49
#3  0x000000000040a7da in main (_argc=1, _argv=0x7fffffffdf78) at /home/nicolas/bzrobot/application/GazeboAgentCameraExample/main.cc:72
Asked by NickDP on 2014-12-12 14:22:44 UTC
Can you get a backtrace from the segmentation fault? Let me know if you need more explanation than that link.
Asked by scpeters on 2014-12-14 05:27:56 UTC
I edited the question to include the backtrace. Can you conclude anything from it?
Asked by NickDP on 2014-12-15 12:26:27 UTC
I don't see the seg-fault in that portion of the backtrace. Can you try thread apply all bt and also paste the gdb error (ie. Program received signal SIGABRT, Aborted.)?
Asked by scpeters on 2014-12-15 13:19:07 UTC
sorry about that. Hopefully now you can find what you're looking for.
Asked by NickDP on 2014-12-15 13:34:57 UTC
Thanks, I'll take a look.
Asked by scpeters on 2014-12-15 13:46:03 UTC
You might be missing some of the calls from Server::Run, such as sensors::run_once(true), and sensors::run_threads()
Asked by scpeters on 2014-12-15 13:55:47 UTC
Interesting, do I have to call these myself? I would have expected setupServer() to take care of this kind of thing. If I add these two commands to my main after loading the world, I the model is loaded, i.e. I can see the box in the world. However, I can't see the camera visualization and there are no frames saved to /tmp/gazebo_frames.
Asked by NickDP on 2014-12-15 14:20:16 UTC
Server.cc is our reference implementation; if it makes those calls, I would expect your program to need to do it as well. I cc'd some of my colleagues who may be able to provide more assistance.
Asked by scpeters on 2014-12-15 15:00:53 UTC
The following is a modified version of your code that should work. The key bit is running a sensor update loop. Sensors that rely on the rendering engine must be run in the main thread. This is a requirement of opengl.
I've create this issue to make it easier to use sensors and create a better example.
#include <gazebo/gazebo.hh>
#include <gazebo/sensors/sensors.hh>
#include <iostream>
int main(int _argc, char **_argv)
  // setup Gazebo server
  if(gazebo::setupServer())
    std::cout << "Gazebo server setup successful\n";
  else
    std::cout << "Gazebo server setup failed!\n";
  gazebo::physics::WorldPtr world = gazebo::loadWorld("worlds/empty.world");
  gazebo::sensors::run_once(true);
  gazebo::sensors::run_threads();
  gazebo::physics::run_worlds();
  // Start the Gazebo GUI
  system("gzclient &");
  std::string cameraString =
    "<?xml version='1.0' ?>"
       "<sdf version='1.5'>"
          "<model name='camera'>"
            "<static>true</static>"
            "<pose>4 -4 4 0 0.5 2.4</pose>"
            "<link name=link>"
               "<visual name='visual'>"
                  "<geometry>"
                    "<box>"
                      "<size>0.1 0.1 0.1</size>"
                    "</box>"
                  "</geometry>"
                "</visual>"
                "<sensor name='camera' type='camera'>"
                  "<camera>"
                    "<horizontal_fov>1.047</horizontal_fov>"
                      "<image>"
                        "<width>1280</width>"
                        "<height>960</height>"
                      "</image>"
                      "<clip>"
                        "<near>0.1</near>"
                        "<far>100</far>"
                      "</clip>"
                      "<save enabled='true'>"
                        "<path>/tmp/gazebo_frames</path>"
                      "</save>"
                    "</camera>"
                    "<always_on>1</always_on>"
                    "<update_rate>50</update_rate>"
                    "<visualize>true</visualize>"
                  "</sensor>"
                "</link>"
              "</model>"
            "</sdf>";
  // insert the camera
  world->SetPaused(true);
  int modelCountBefore = world->GetModelCount();
  world->InsertModelString(cameraString);
  world->SetPaused(false);
  int retry=0;
  while (world->GetModelCount() == modelCountBefore)
    gazebo::common::Time::MSleep(100);
    retry++;
    if (retry>1000)
      break;
  if(world->GetModelCount() == modelCountBefore+1)
    std::cout << "Successfully inserted model.\n";
  else
    std::cout << "Failed inserting model\n";
  while(true)
    gazebo::sensors::run_once(0);
  gazebo::shutdown();
Asked by nkoenig on 2014-12-16 10:56:54 UTC
With this addition the example code works. However, in my actual application I still can't get it to work. I wrote a library that runs the Gazebo server and allows me to insert and manipulate models. In my main I have an instance of that class and go through some sample poses etc. So I can't have my main be stuck in this while loop. Am I understanding correctly that there is no way to move the sensor update into my library, for example in a callback to Events::ConnectWorldUpdateBegin?
Asked by NickDP on 2014-12-16 14:24:50 UTC
