Visualizing LIDAR on active tilting sensor; hiding LIDAR visualization on inactive sensor
In the current PR2 model and running Gazebo 4.0, I turn off the base laser and activate the tilting laser for the PR2 model. It appears when starting the simulation that the former is active (I see a blue light emanating from it) and the latter is not (I see no such light). However, I can read values properly from the tilting laser (after first calling SetActive(true)). This is not a big issue- the code works properly- but the visual artifact is jarring. Am I doing something wrong?
