cloudsim will not install
ubuntu@domU-12-31-39-02-32-67:~$ sudo apt-get install cloud-utils drcsim python zip unzip openvpn openssh-client ros-fuerte-visualization
Reading package lists... Done
Building dependency tree
cloud-utils is already the newest version.
openssh-client is already the newest version.
python is already the newest version.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 drcsim : Depends: gazebo (>= 1.2.0) but it is not going to be installed
 ros-fuerte-visualization : Depends: ros-fuerte-visualization-common (= 1.8.4-s1347128602~precise) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Asked by aqiruse on 2013-01-13 17:14:18 UTC
Can you try:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install drcsim
Asked by nkoenig on 2013-01-13 17:24:25 UTC
Here is a copy from the command line when I try to perform the update, upgrade, install routine. I tried three times, and this is the output I received the third time. Each time it failed to install drcsim.
sudo apt-get update Ign http://us-east-1.ec2.archive.ubuntu.com precise InRelease Ign http://us-east-1.ec2.archive.ubuntu.com precise-updates InRelease
Ign http://security.ubuntu.com precise-security InRelease
Hit http://us-east-1.ec2.archive.ubuntu.com precise Release.gpg
Hit http://us-east-1.ec2.archive.ubuntu.com precise-updates Release.gpg
Get:1 http://security.ubuntu.com precise-security Release.gpg [198 B]
Get:2 http://security.ubuntu.com precise-security Release [49.6 kB]
Hit http://us-east-1.ec2.archive.ubuntu.com precise/main Sources
Hit http://us-east-1.ec2.archive.ubuntu.com precise/universe Sources
Hit http://us-east-1.ec2.archive.ubuntu.com precise/main amd64 Packages
Get:3 http://security.ubuntu.com precise-security/main Sources [61.3 kB]
Hit http://us-east-1.ec2.archive.ubuntu.com precise/universe amd64 Packages
Hit http://us-east-1.ec2.archive.ubuntu.com precise/main i386 Packages
Hit http://us-east-1.ec2.archive.ubuntu.com precise/universe i386 Packages
Hit http://us-east-1.ec2.archive.ubuntu.com precise/main TranslationIndex
Hit http://us-east-1.ec2.archive.ubuntu.com precise/universe TranslationIndex
Hit http://us-east-1.ec2.archive.ubuntu.com precise-updates/main Sources
Hit http://us-east-1.ec2.archive.ubuntu.com precise-updates/universe Sources
Hit http://us-east-1.ec2.archive.ubuntu.com precise-updates/main amd64 Packages Hit http://us-east-1.ec2.archive.ubuntu.com precise-updates/universe amd64 Packages Get:4 http://security.ubuntu.com precise-security/universe Sources [20.0 kB]
Hit http://us-east-1.ec2.archive.ubuntu.com precise-updates/main i386 Packages Hit http://us-east-1.ec2.archive.ubuntu.com precise-updates/universe i386 Packages Hit http://packages.osrfoundation.org precise InRelease
Get:5 http://security.ubuntu.com precise-security/main amd64 Packages [220 kB] Hit http://us-east-1.ec2.archive.ubuntu.com precise-updates/main TranslationIndex Hit http://us-east-1.ec2.archive.ubuntu.com precise-updates/universe TranslationIndex Hit http://us-east-1.ec2.archive.ubuntu.com precise/main Translation-en
Hit http://us-east-1.ec2.archive.ubuntu.com precise/universe Translation-en
Hit http://us-east-1.ec2.archive.ubuntu.com precise-updates/main Translation-en Hit http://us-east-1.ec2.archive.ubuntu.com precise-updates/universe Translation-en Get:6 http://security.ubuntu.com precise-security/universe amd64 Packages [61.8 kB] Get:7 http://security.ubuntu.com precise-security/main i386 Packages [228 kB]
Hit http://packages.osrfoundation.org precise/main amd64 Packages
Get:8 http://security.ubuntu.com precise-security/universe i386 Packages [63.1 kB] Hit http://security.ubuntu.com precise-security/main TranslationIndex
Ign http://packages.ros.org precise InRelease
Hit http://security.ubuntu.com precise-security/universe TranslationIndex
Hit http://security.ubuntu.com precise-security/main Translation-en
Hit http://packages.osrfoundation.org precise/main i386 Packages
Hit http://security.ubuntu.com precise-security/universe Translation-en
Hit http://packages.ros.org precise Release.gpg
Ign http://packages.osrfoundation.org precise/main TranslationIndex
Hit http://packages.ros.org precise/main amd64 Packages
Hit http://packages.ros.org precise/main i386 Packages
Ign http://packages.ros.org precise/main TranslationIndex Ign http://packages.osrfoundation.org precise/main Translation-en_US Ign http://packages.osrfoundation.org precise/main Translation-en Ign http://packages.ros.org precise/main Translation-en_US Ign http://packages.ros.org precise/main Translation-en Fetched 703 kB in 1s (453 kB/s) Reading package lists... Done
sudo apt-get upgrade Reading package lists... Done Building dependency tree
Reading state information... Done The following packages have been kept back: linux-image-virtual linux-virtual 0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
sudo apt-get install drcsim Reading package lists... Done Building dependency tree
Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: drcsim : Depends: gazebo (>= 1.2.0) but it is not going to be installed E: Unable to correct problems, you have held broken
Asked by aqiruse on 2013-01-28 21:02:13 UTC
