openni kinect causing source build error in Gazebo 1.9 with Groovy ROS
I am building Gazebo 1.9 with Groovy ROS. I followed the instructions pertaining to Hydro source installation here.
I changed git clone https://github.com/ros-simulation/gazebo_ros_pkgs.git -b hydro-devel to git clone https://github.com/ros-simulation/gazebo_ros_pkgs.git -b groovy-devel.
The rosdep check was ok saying that all dependencies are met. When I run catkin_make to build the pacakages this errors keep appearing:
make[2]: *** [gazebo_ros_pkgs/gazebo_plugins/CMakeFiles/gazebo_ros_openni_kinect.dir/src/gazebo_ros_openni_kinect.cpp.o] Error 1
    make[1]: *** [gazebo_ros_pkgs/gazebo_plugins/CMakeFiles/gazebo_ros_openni_kinect.dir/all] Error 2
Can anyone provide a solution?
Asked by RoboC on 2014-12-19 06:35:49 UTC
I would recommend to move to hydro as soon as possible. I'm not sure that gazebo_ros_pkgs is maintaining the groovy support anymore. Anyway, you need to provide the compilation output with the error line (not just the two final lines) so please edit the question and complete the output.
Asked by Jose Luis Rivero on 2014-12-19 10:56:03 UTC
