Invalid <param> tag: Cannot load Husky into gazebo
Hello, I am currently running the Husky packages on gazebo-4.0. It worked fine till yesterday, but when I run it again using roslaunch it shows following error
 rahul@rahul-pc:~/husky_ws$ roslaunch husky_gazebo husky_empty_world.launch
... logging to /home/rahul/.ros/log/014e7106-9478-11e4-b211-a4db30d7dfe6/roslaunch-rahul-pc-4352.log
Press Ctrl-C to interrupt
  File "/opt/ros/indigo/share/xacro/xacro.py", line 60, in <module>
    xacro.main()
AttributeError: 'module' object has no attribute 'main'
while processing /home/rahul/sample_ws/src/husky_gazebo/launch/base.urdf.gazebo.launch:
Invalid <param> tag: Cannot load command parameter [robot_description]: command [/opt/ros/indigo/share/xacro/xacro.py        '/home/rahul/sample_ws/src/husky_description/urdf/base.urdf.xacro'          gps_enabled:=true         imu_enabled:=true  front_laser:=true     ] returned with code [1].
Param xml is <param command="$(find xacro)/xacro.py        '$(find husky_description)/urdf/base.urdf.xacro'          gps_enabled:=$(arg gps_enabled)         imu_enabled:=$(arg imu_enabled)  front_laser:=$(arg front_laser)     " name="robot_description"/>
The traceback for the exception was written to the log file
I don't know how to solve this problem. A little help would be appreciated. Thank you for your useful time
Regards,
Rahul
Asked by Rahul Sharma on 2015-01-04 20:24:11 UTC
I had a similar issue when trying to update and run the husky simulation in indigo. I believe that the current git repo is still in devel and hence full sync is not available yet. Try cloning the urdf directory at https://github.com/husky/husky_simulator.git under the husky_gazebo folder and adding it to the /opt/ros/indigo/share/husky_gazebo folder. Make sure to change file permissions to allow writing.
Hope this helps.
Asked by zeonzir on 2015-03-09 12:03:46 UTC
