unable to parse message of type [...] error in custom message
asked 2015-01-13 13:29:25 -0500
djou07 gravatar image
updated 2015-01-13 13:33:12 -0500
I am trying to send a custom message from a model plugin to another model plugin. The two plugins are linked to same model. The code compiles well, but when I run gazebo GUI it shows me this error in topic visualisation:
unable to parse message of type[robot_brain_fitness_msgs.msgs.robotDataRequest]
I do not why, can you guys help me...thanks in advance :)
here is the source code
in subfolder msgs
/msgs/robot_brain_fitness.proto
package robot_brain_fitness_msgs.msgs;
message robotDataRequest
   required double fitness = 1;
/msgs/CMakeLists.txt
find_package(Protobuf REQUIRED)
set(PROTOBUF_IMPORT_DIRS)
foreach(ITR ${GAZEBO_INCLUDE_DIRS})
  if(ITR MATCHES ".*gazebo-[0-9.]+$")
    set(PROTOBUF_IMPORT_DIRS "${ITR}/gazebo/msgs/proto")
  endif()
endforeach()
set (msgs
  ${PROTOBUF_IMPORT_DIRS}/vector2d.proto
  ${PROTOBUF_IMPORT_DIRS}/header.proto
  ${PROTOBUF_IMPORT_DIRS}/time.proto
PROTOBUF_GENERATE_CPP(PROTO_SRCS PROTO_HDRS ${msgs})
add_library(robot_brain_fitness_msgs SHARED ${PROTO_SRCS})
target_link_libraries(robot_brain_fitness_msgs ${PROTOBUF_LIBRARY})
in root folder
plugin1.cc
#include <boost/bind.hpp>
#include <gazebo/gazebo.hh>
#include <stdio.h>
#include <iostream>
#include "robot_brain_fitness.pb.h"
namespace gazebo
typedef const boost::shared_ptr
    <const robot_brain_fitness_msgs::msgs::robotDataRequest>   robotDataRequestPtr;
    class ReceiveMsgPlugin : public ModelPlugin
             physics::ModelPtr model;
             transport::SubscriberPtr subscriber;
             transport::NodePtr node;
        //subscriber = node->Subscribe("~/robotData", &ReceiveMsgPlugin::create, this);
        this->updateConnection = event::Events::ConnectWorldUpdateBegin
            ( boost::bind(&ReceiveMsgPlugin::OnUpdate, this, _1));
    /*public: void create(robotDataRequestPtr &msg)
        std::cout << "fitness : " <<msg->fitness() << "\n";
    public: void OnUpdate(const common::UpdateInfo & /*_info*/)
 GZ_REGISTER_MODEL_PLUGIN(ReceiveMsgPlugin)
plugin2.cc
#include <stdio.h>
#include <iostream>
namespace gazebo
 class SendMsgPlugin : public ModelPlugin
         transport::PublisherPtr publisher;
    this->model = _parent;
     node = transport::NodePtr(new transport::Node());
     node->Init(this->model->GetWorld()->GetName());
        ( boost::bind(&SendMsgPlugin::OnUpdate, this, _1));
        robot_brain_fitness_msgs::msgs::robotDataRequest request;
        request.set_fitness(10);
        publisher = node->Advertise
          <robot_brain_fitness_msgs::msgs::robotDataRequest>("~/robotData");
        publisher->Publish(request);
GZ_REGISTER_MODEL_PLUGIN(SendMsgPlugin)
CMakeLists.txt
cmake_minimum_required(VERSION 2.8.8 FATAL_ERROR)
FIND_PACKAGE( Boost 1.40 COMPONENTS system REQUIRED )
set (CMAKE_CXX_FLAGS "-g -Wall")
include (FindPkgConfig)
if (PKG_CONFIG_FOUND)
  pkg_check_modules(GAZEBO gazebo)
  pkg_check_modules(SDF sdformat)
endif()
include_directories(
  ${CMAKE_CURRENT_BINARY_DIR}/msgs
link_directories(${GAZEBO_LIBRARY_DIRS} ${SDF_LIBRARY_DIRS} ${CMAKE_CURRENT_BINARY_DIR}/msgs)
add_subdirectory(msgs)
add_library(plugin1 SHARED plugin1.cc)
target_link_libraries(plugin1 robot_brain_fitness_msgs
${Boost_LIBRARIES} ${GAZEBO_LIBRARIES} ${SDF_LIBRARIES})
add_dependencies(plugin1 robot_brain_fitness_msgs)
add_library(plugin2 SHARED plugin2.cc)
target_link_libraries(plugin2 robot_brain_fitness_msgs ${Boost_LIBRARIES}
add_dependencies(plugin2 robot_brain_fitness_msgs)
answered 2015-01-15 10:27:35 -0500
nkoenig gravatar image
The problem is that the Gazebo GUI doesn't know about your custom message, so it can't display it in the topic visualizer. There is no easy solution. If you want to quickly see the content of the message, you can print it to the terminal (or to a log file) in your plugin.
This problem will be fixed in Gazebo 6, when we update the transport library.
Asked: 2015-01-13 13:29:25 -0500
Seen: 1,288 times
Last updated: Jan 15 '15
