Modifying OpenNI Kinect plugin to get back disparity data again? gazebo_ros_openni_kinect.so
asked 2013-01-14 05:25:33 -0500
dbworth gravatar image
updated 2013-07-23 17:41:13 -0500
hsu gravatar image
https://code.ros.org/trac/ros-pkg/browser/stacks/simulator_gazebo/trunk/gazebo_plugins/src/gazebo_ros_openni_kinect.cpp
Hi all,
I thought this was the most appropriate place to post this.
If you look at the above plugin, the functionality to return disparity data was removed, as opposed to the deprecated driver.
** How can I modify this plugin to return disparity data?
I'm happy to help, I just don't understand what the blocker is.
Alternatively, can I run some processing nodes on ROS to generate disparity data?
Cheers,
David.
answered 2013-07-23 18:18:50 -0500
hsu gravatar image
We are moving towards running gazebo as a system install against ROS. Gazebo ROS plugins developments have been moved to gazebo_ros_pkgs repository, you can find corresponding gazebo_ros_openni_kinect.cpp source here. For reference, please take a look at tutorial on installing gazebo_ros_pkgs and the How to Contribute Page. Please start by filing an issue on the issue tracker. And possibly followed by creating a pull request with patch fix in your branch? Thanks!
Asked: 2013-01-14 05:25:33 -0500
Seen: 552 times
Last updated: Jul 23 '13
