Error Gazebo URDF Opening
Hi guys, I'm working with an hexapod in a project, so i need to import it from solid works to gazebo. I tried to use an URDF exporter, and it generated an folder with 2 launchs (gazebo.launch & display.launch). I tried to execute the gazebo.launch with roslaunch. It bring me an error https://gist.github.com/anonymous/5e56cbfb2f6b3f24de0d
So I openned my .launch file: https://gist.github.com/anonymous/244301079d768c7aaf75
And change some lines, getting this: https://gist.github.com/anonymous/57f95f42fb4b5cfc4ebc
And now it is returning the following error: https://gist.github.com/anonymous/6f603553edcc25128ae5
Someone know waht should i do?
Asked by Marcio Montenegro on 2015-02-03 10:22:39 UTC
gazebo_worlds
was last used in groovy. It looks like you're using hydro, so you should use some example launch files from hydro.
Asked by scpeters on 2015-02-04 19:39:44 UTC
You can try loading your model without ROS by doing:
- Locate your URDF file.
- Run:
gz sdf -p REPLACE_WITH_URDF_FILE > model.sdf
Create a world file with:
<?xml version="1.0" ?> <sdf version="1.5"> <world name="default"> <include><uri>model://sun</uri></include> <include><uri>model://ground_plane</uri></include> COPY THE CONTENTS OF model.sdf HERE </world> </sdf>
Run gazebo:
gazebo THE_WORLD_FILE_CREATED_IN_STEP3
Asked by nkoenig on 2015-02-05 10:24:23 UTC
both the launch file (empty_world.launch
) and model spawning script (spawn_model
) are now in a package called gazebo_ros
, so try replacing
<launch>
<include
file="$(find gazebo_worlds)/launch/empty_world.world" />
<node
name="tf_footprint_base"
pkg="tf"
type="static_transform_publisher"
args="0 0 0 0 0 0 base_link base_footprint 40" />
<node
name="spawn_model"
pkg="gazebo"
type="spawn_model"
args="-file $(find hexapod_launch)/robots/hexapod_launch.URDF-urdf -model hexapod_launch"
output="screen" />
<node
name="fake_joint_calibration"
pkg="rostopic"
type="rostopic"
args="pub /calibrated std_msgs/Bool true" />
</launch>
with
<launch>
<include
file="$(find gazebo_ros)/launch/empty_world.launch" />
<node
pkg="tf"
<node
name="spawn_model"
pkg="gazebo_ros"
type="spawn_model"
output="screen" />
<node
pkg="rostopic"
type="rostopic"
</launch>
that should get you past the errors you posted
ResourceNotFound: gazebo_worlds
and
ERROR: cannot launch node of type [gazebo/spawn_model]: gazebo
Asked by hsu on 2015-02-05 19:08:29 UTC
What version of Gazebo are you using?
Asked by nkoenig on 2015-02-03 10:49:31 UTC
4.0 sir '-'
Asked by Marcio Montenegro on 2015-02-03 20:47:49 UTC
