Modified UR10 wont load!
Dear Gazebo Users,
I have been working now in Gazebo for a while and managed to play around with the UR10 model by attaching some sensors to it and it all loaded fine, I wanted to make all my Simulation move so i decided to lunch it in ROS and Simulate it in Gazebo using these Commands:
roslaunch urgazebo ur10.launch limited:=true roslaunch ur10moveitconfig ur10moveitplanningexecution.launch sim:=true limited:=true roslaunch ur10moveitconfig moveit_rviz.launch config:=true
Then I got the error that it cannot find launch files! After Installing libsdfromat1 it worked just as it should however the Modified UR10.sdf didnt load up giving me this error:
Error [Converter.cc:127] Unable to convert from SDF version 1.5 to 1.4
Error [parser.cc:697] XML Element[useparentmodelframe], child of element[axis] not defined in SDF. Ignoring.[axis]
Error [parser.cc:688] Error reading element
I thought i can overcome this Error by Installing the libsdformat2-dev, it did Solve the Problem for loading the Model in Gazebo but the commands
Didn't work.
I decided to change the model.config (by adding the sdf model 1.4 line) and by changing the sdf version from 1.5 to 1.4. Tried to load the model again but i got the same error as above without the line saying: Error [Converter.cc:127] Unable to convert from SDF version 1.5 to 1.4
Is there anyone who can help me solve this problem.
Thank you very much! I hope the Question was as clear as possible.
Kind Regards ,
E.Raci - Automotive Systems Engineering/ University Heilbronn / Germany.
P.S How is it possible to load the Robot model i have modified for example ur10_modified.urdf in ROS. I want to move this Model and to see the Simulation in Gazebo
Asked by edo_raci on 2015-03-05 04:59:08 UTC
