GZWEB ONLY WORKS WITH THE BASIC FORM
Hi everyone!!
I have a problem trying to simulate my robot on gzweb. I have my simulation on gazebo that works perfectly and when i run gzweb only appear the basic forms as a box or wall... that come with gzweb.
i have made export GAZEBOMODELPATH=/myrobotmodel:$GAZEBOMODELPATH.
i show in readme that when you execute ./deploy -m your model load on the server. But that command fail. It say me that model.sdf have a 1.5 and have to convert to 1.4. But that appear in the basic models of gzweb... What could i make?
what am i making worng?
my versions are gazebo2-2, ubuntu 14.04, ros indigo
Asked by zior on 2015-03-05 06:33:16 UTC
Can you add to your question the errors you get when running ./deploy.sh -m ? After running that, can you find your model under gzweb/http/client/assests?
Asked by chapulina on 2015-03-05 12:22:15 UTC
that the error that give me the deploy.sh script:
Warning [parser.cc:340] Converting a deprecated source[/home/zgallo/gzweb/tools/../http/client/assets/asphalt_plane/model.sdf]. Warning [Converter.cc:59] Version[1.5] to Version[1.4] Please use the gzsdf tool to update your SDF files. $ gzsdf convert [sdf_file] Error [Converter.cc:127] Unable to convert from SDF version 1.5 to 1.4 Msg Waiting for master Msg Connected to gazebo master @ http://127.0.0.1:11345 Msg Publicized address: 10.1.22.82 Error [Node.cc:90] No namespace found
and my model doesn't appear on /gzweb/http/client/assest
it appear on /gzweb/mymodel
Asked by zior on 2015-03-06 03:13:12 UTC
I'm having the same issue, did anyone manage to fix this? Thanks!
Asked by Gary Servin on 2016-01-04 13:54:56 UTC
