Ros Gazebo create joint between Object and Robot Arm with Service
Hello All
I'm currently building a simulation for an omni directional platform with a robot arm on top, everything is working fine except for grasping. I read that physics based grasping is not that reliable and never got it to work either.
So I want to create a Ros_Node which checks if the Object is between the Fingers and than attaches the object with a fixed joint on the tcp of my robot arm. Any help would be greatly appreciated.
I am using Gazebo 5.0.1 and ROS Indigo.
Asked by lukepro on 2015-03-10 02:18:11 UTC
