Joints won't hold in place
Not really sure what i should be doing with my model, i have a prismatic joint which slides downwards due to gravity. What I want is for somehow the joint to not slide down to its lower bound before I can attach my controllers which will determine its positional value. I tried giving the joint friction using dynamics tags in the joint properties in the URDF.
Any ideas how to fix this problem
Asked by adam896 on 2015-03-23 12:00:16 UTC
What I ended up having to do to get around this was to launch my controllers simultaneously and have their signals hold the joints where i wanted them to, still not convinces this is a perfect solution as I believe I require some sort of friction value in the joint itself which would hold it in place without the need for controllers.
Asked by adam896 on 2015-03-24 10:18:04 UTC
