90-oculus.rules might have broken 90-hydra.rules
so I tried out Oculus dk2 in Gazebo, it worked, nice job! However, now I cannot connect my Razer Hydra device:
[Err] [Plugin.hh:153] Failed to load plugin libHydraPlugin.so: libHydraPlugin.so: cannot open shared object file: No such file or directory
I tried all my USB ports, reloaded the rules, restarted pc, removed all the rules and only added the hydra one, still no change.
I had this error before, and then I only managed to get it to work after I re-installed Ubuntu. I would like to avoid that this time :)
I looked over these rules, and is it normal that both use the same SUBSYSTEM name?
90-oculus.rules :
# Oculus HID Sensor naming and permissioning
KERNEL=="hidraw*", SUBSYSTEM=="hidraw", ATTRS{idVendor}=="2833", MODE="0666"
90-hydra.rules:
ATTRS{idProduct}=="0300",ATTRS{idVendor}=="1532",ATTR{bInterfaceNumber}=="00",TAG="hydra-tracker"
SUBSYSTEM=="hidraw",TAGS=="hydra-tracker", MODE="0666", SYMLINK+="hydra"
I am using 14.04 and Gazebo from default.
Cheers, Andrei
Asked by AndreiHaidu on 2015-03-27 08:17:05 UTC
Andrei, what is driving you to think that the problem is in udev? The message says the the plugin library was not found by the loader. Manually adjusting LD_LIBRARY_PATH helps?
Asked by Jose Luis Rivero on 2015-04-01 17:59:33 UTC
Wow, I don't know how I missed that, it does work, thanks :)
Asked by AndreiHaidu on 2015-04-09 06:14:06 UTC
These two files have worked simultaneously. As Jose pointed out, it looks like gazebo couldn't find the libhydraplugin. Can you check your GAZEBO_PLUGIN_PATH environment variable?
Asked by nkoenig on 2015-04-02 09:26:04 UTC
yup, that was the issue, my bad :)
Asked by AndreiHaidu on 2015-04-09 06:15:27 UTC
