How to draw line or path in gazebo or is any model for line exist?
I want to create line or path. I am attaching my code but nothing is displayed.I want to use world plugin instead of system plugin, but I am not able to get how to pass the name parameter. I also tried with system plugin but then also nothing was shown. Is it the ogre issue. Here I am attaching my world plugin code. Any help would be appreciated. Thanks!
namespace gazebo
namespace rendering
class ModelPush1 : public WorldPlugin
private:physics::WorldPtr world;
public:boost::thread draw;
private: Ogre::SceneManager *manager;
Ogre::SceneNode *sceneNode ;
Ogre::ManualObject *obj;
public: void Load(physics::WorldPtr _parent, sdf::ElementPtr _sdf)
std::cout<<"loading rfid world"<<std::endl;
world = _parent;
this->updateConnection = event::Events::ConnectWorldUpdateBegin(boost::bind(&ModelPush1::OnUpdate, this, _1));
this->draw=boost::thread(boost::bind(&ModelPush1::draw_line, this));
public: void draw_line()
bool attached = false;
if (this->manager->hasManualObject("ground_plane"))
sceneNode = this->manager->getSceneNode("ground_plane");
obj = this->manager->getManualObject("ground_plane");
attached = true;
else
sceneNode = this->manager->getRootSceneNode()->createChildSceneNode("ground_plane");
obj = this->manager->createManualObject("ground_plane");
sceneNode->setVisible(true);
obj->setVisible(true);
obj->clear();
obj->begin("Gazebo/Red", Ogre::RenderOperation::OT_LINE_LIST);
obj->position(12, 12, 0);
obj->position(20,20, 0);
obj->end();
if (!attached)
sceneNode->attachObject(obj);
public: void OnUpdate(const common::UpdateInfo & /*_info*/)
std::cout<<"loading"<<std::endl;
GZ_REGISTER_WORLD_PLUGIN(ModelPush1)
Asked by anonymous on 2015-04-17 06:59:02 UTC
Hi, you can have a look at this:
http://answers.gazebosim.org/question/3383/how-to-add-a-dynamic-visual-marker-in-gazebo/#3394
And otherwise you would probably need to create a model for a line.
Cheers
EDIT:
As stated in one of your comments, if you just want to do following, create a model/texture with (a) line(s) on it. Use Blender/SketchUp or any Image manipulation program
Asked by ffurrer on 2015-04-18 03:44:05 UTC
Thank You for the reply. I tried with this also , but then it is not loading the visual plugin . Here I am attaching my code.
namespace gazebo {
namespace rendering {
class ModelPush1 : public VisualPlugin {
private: event::ConnectionPtr update_connection_;
private:VisualPtr visual_;
private:ScenePtr scene_;
private:DynamicLines *line;
public: void Load( VisualPtr _parent, sdf::ElementPtr _sdf ) {
this->visual_ = _parent;
this->update_connection_ = event::Events::ConnectRender(boost::bind(&ModelPush1::UpdateChild, this));
this->draw=boost::thread(boost::bind(&ModelPush1::visualise_line, this));
public:void UpdateChild() {
while(1)
std::cout<<"data"<<std::endl;
public: void visualise_line() { std::cout<<"data"<<std::endl;
this->line= this->visual_->CreateDynamicLine(RENDERING_LINE_STRIP);
this->line->AddPoint(math::Vector3(12, 12, 0));
this->line->AddPoint(math::Vector3(15, 15, 0));
this->line->setMaterial("Gazebo/Purple");
this->line->setVisibilityFlags(GZ_VISIBILITY_GUI);
this->line->setVisible(true);
GZ_REGISTER_VISUAL_PLUGIN(ModelPush1) } }
And my sdf file is
<?xml version='1.0'?>
<link name="my_visual_link">
<visual name="my_visual">
<plugin name="SomeVisualPlugin" filename="libSomeVisualPlugin.so"/>
<pose>0 0 0 0 0 0</pose>
<empty>
</empty>
<uri>model://sun</uri>
Asked by anonymous on 2015-04-18 05:15:34 UTC
well you should load the same shared library (.so) file as you generate. libSomeVisualPlugin.so is most likely wrong.
Asked by ffurrer on 2015-04-18 06:04:20 UTC
I am loading the same shared library as generated by code . My code filename is SomeVisualPlugin.cc and after cmake , it generated the libSomeVisualPlugin.so. But, I even export GAZEBO_PLUGIN_PATH, but still is not loading my plugin and nothing is displayed. My normal code world plugin and model plugin code are easily loading , but only this has some issues, might be because something wrong in code. Is it mandatory to use gazebo msgs, because i have done without that .
Asked by anonymous on 2015-04-18 07:33:32 UTC
I want to create line , because I want to do line following. so I think line model wont work.
Asked by anonymous on 2015-04-18 07:35:18 UTC
I'm not sure, what the problem is, did you try to run the example in my link? For your purpose I would really consider just creating a model/texture with some lines on it. I guess if you don't want to dynamically change the lines, this should be the easiest solution.
Asked by ffurrer on 2015-04-20 02:58:14 UTC
