Unable to load controller into parameter server
How do you load your controller via rosservice?
I'm trying to follow the ROS Control tutorial but I'm getting stuck at the step:
rosservice call /rrbot/controller_manager/load_controller "name: 'joint1_position_controller'"
which gives me the error:
ERROR: Service [/rrbot/controller_manager/load_controller] is not available.
Is there some step missing? If I try to run that while the two other roslaunch commands are still running, I get a different error:
ok: False
Exception in thread Thread-3 (most likely raised during interpreter shutdown):
  File "/usr/lib/python2.7/threading.py", line 810, in __bootstrap_inner
  File "/usr/lib/python2.7/threading.py", line 763, in run
  File "/opt/ros/indigo/lib/python2.7/dist-packages/rospy/impl/tcpros_base.py", line 154, in run
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'timeout'
If I try to re-run that, sometimes I only get the "ok: False" and no traceback. Does the "ok: False" still indicate an error?
What am I doing wrong?
Asked by Cerin on 2015-05-02 14:31:20 UTC
Do you still have this problem? I had a similar issue when I was trying to use ros_control in Jade. My problem was that I did not have the package effort_controllers installed and so I could not create any controllers. Try calling the service /rrbot/controller_manager/list_controller_types to see if you have any controller types available. Also, you may need to add the namespace to the controller name:
rosservice call /rrbot/controller_manager/load_controller "name: '/rrbot/joint1_position_controller'"
Asked by agoins on 2015-08-18 14:40:10 UTC
