How getvelocity function works ?
I wanted to get the velocity of a joint of my model using GetVelocity() function but can anyone tell me how to use this function. I saw this link http://osrf-distributions.s3.amazonaws.com/gazebo/api/dev/classgazebo_1_1physics_1_1Joint.html Here I found the description but I am still not able to figure out how it works because they have mentioned that in parameters you have to give int value but how can I tell gazebo which joint's velocity do I need to know in this way? Shouldn't I give the whole name of the joint ?
Asked by akshay5059 on 2015-05-13 06:58:05 UTC
If you want to get the velocity of a joint, you first need to get the joint pointer from your model using Model::GetJoint() by passing the joint name you want to get the velocity. Then Joint::GetVelocity(int index) will return the velocity of a specific dof in the joint. This index is for the joint that contains multiple dofs in the joints like HingeJoint, UniversalJoint, and BallJoint. Note that passing invalid index would return 0 value for the velocity.
Asked by JS on 2015-05-13 15:45:34 UTC
Thank you JS for the information. You said that we need joint pointer but when I revisited the link I have mentioned in my question, I found out that in this case, we would rather need Base Pointer in constructor of gazebo::physics::Joint. Can you tell me what base pointer is and how to get it ?
Asked by akshay5059 on 2015-05-19 09:07:01 UTC
I made a gazebo::physics::JointPtr to store my joint objects.
Asked by lrupert1 on 2018-05-21 14:36:14 UTC
The index should be zero for any single-axis joints (revolute or prismatic), and can be 0 or 1 for 2-axis joints like universal.
Asked by scpeters on 2015-05-14 02:37:37 UTC
