Error :XML Element[sensor], child of element[model] not defined in SDF. Ignoring.[model] child while adding sonar sensor plugin
Trying to add sonar sensor to my bot and using pal-robotic/reems_plugin . Till now, able to compile the code with few warnings.
Made following changes in order to use this plugin
<sensor name ="sonar" type="ray">
<rayCount>5</rayCount>
<rangeCount>5</rangeCount>
<verticalRayCount>1</verticalRayCount>
<verticalRangeCount>1</verticalRangeCount>
<minAngle>-16</minAngle>
<verticalMinAngle>-16</verticalMinAngle>
<maxAngle>16</maxAngle>
<verticalMaxAngle>16</verticalMaxAngle>
<minRange>0</minRange>
<maxRange>7</maxRange>
<resRange>0.01</resRange>
<plugin name="gazebo_ros_sonar_controller" filename ="libgazebo_ros_sonar.so">
<alwaysOn>true<alwaysOn>
<updateRate>10</updateRate>
<topicName>sonar</topicName>
<frameId>base</frameId>
<radiation>infrared</radiation>
<fov>32</fov>
where my already existing sdf file is :
<?xml version="1.0" ?>
<sdf version="1.4">
<model name="create">
<link name="base">
<pose>0.001453 -0.000453 0.029787 0 0 0</pose>
<ixx>0.058640</ixx>
<ixy>0.000124</ixy>
<ixz>0.000615</ixz>
<iyy>0.058786</iyy>
<iyz>0.000014</iyz>
<izz>1.532440</izz>
<mass>2.234000</mass>
<collision name="base_collision">
<pose>0 0 0.047800 0 0 0</pose>
<cylinder>
<radius>0.016495</radius>
<length>0.061163</length>
</cylinder>
<visual name="base_visual">
<mesh>
<uri>model://create/meshes/create_body.dae</uri>
</mesh>
<collision name="front_wheel_collision">
<pose>0.130000 0 0.017000 0 1.570700 1.570700</pose>
<sphere>
<radius>0.018000</radius>
</sphere>
<surface>
<friction>
<ode>
<mu>0</mu>
<mu2>0</mu2>
<fdir1>0 0 0</fdir1>
<slip1>0</slip1>
<slip2>0</slip2>
</ode>
</friction>
</surface>
<visual name="front_wheel_visual">
<sphere>
<radius>0.009000</radius>
</sphere>
<collision name="rear_wheel_collision">
<pose>-0.13 0 0.017 0 1.5707 1.5707</pose>
<sphere>
<radius>0.015000</radius>
</sphere>
<surface>
<friction>
<ode>
<mu>0</mu>
<mu2>0</mu2>
<slip1>0</slip1>
<slip2>0</slip2>
</ode>
</friction>
</surface>
<visual name="rear_wheel_visual">
<pose>-0.130000 0 0.017000 0 1.570700 1.570700</pose>
<sphere>
<radius>0.007500</radius>
</sphere>
<sensor name="left_cliff_sensor" type="ray">
<pose>0.070000 0.140000 0.027000 0 1.570790 0</pose>
<ray>
<scan>
<horizontal>
<samples>1</samples>
<resolution>1.000000</resolution>
<min_angle>0</min_angle>
<max_angle>0</max_angle>
</horizontal>
</scan>
<range>
<min>0.010000</min>
<max>0.040000</max>
<resolution>0.100000</resolution>
</range>
</ray>
<sensor name="leftfront_cliff_sensor" type="ray">
<pose>0.150000 0.040000 0.027000 0 1.570790 0</pose>
<ray>
<scan>
<horizontal>
</horizontal>
</scan>
<range>
<min>0.010000</min>
<max>0.040000</max>
</range>
</ray>
<sensor name="right_cliff_sensor" type="ray">
<pose>0.070000 -0.140000 0.027000 0 1.570790 0</pose>
<ray>
<scan>
<horizontal>
</horizontal>
</scan>
<range>
<min>0.010000</min>
<max>0.040000</max>
</range>
</ray>
<sensor name="rightfront_cliff_sensor" type="ray">
<pose>0.150000 -0.040000 0.027000 0 1.570790 0</pose>
<ray>
<scan>
<horizontal>
</horizontal>
</scan>
<range>
<min>0.010000</min>
<max>0.040000</max>
</range>
</ray>
<sensor name="wall_sensor" type="ray">
<pose>0.090000 -0.120000 0.059000 0 0 -1.000000</pose>
<ray>
<scan>
<horizontal>
</horizontal>
</scan>
<range>
<min>0.016000</min>
<max>0.040000</max>
</range>
</ray>
<link name="left_wheel">
<pose>0 0.130000 0.032000 0 0 0</pose>
<ixx>0.001000</ixx>
<iyy>0.001000</iyy>
<izz>0.001000</izz>
<mass>0.010000</mass>
<pose>0 0 0 0 1.570700 1.570700</pose>
<cylinder>
<radius>0.033000</radius>
<length>0.023000</length>
</cylinder>
<surface>
<friction>
<ode>
<mu>10</mu>
<mu2>10</mu2>
<slip1>0</slip1>
<slip2>0</slip2>
</ode>
</friction>
</surface>
<cylinder>
</cylinder>
<link name="right_wheel">
<pose>0 -0.130000 0.032000 0 0 0</pose>
<ixx>0.001000</ixx>
<iyy>0.001000</iyy>
<izz>0.001000</izz>
<cylinder>
</cylinder>
<surface>
<friction>
<ode>
<mu>10</mu>
<mu2>10</mu2>
<slip1>0</slip1>
<slip2>0</slip2>
</ode>
</friction>
</surface>
<cylinder>
</cylinder>
<joint name="left_wheel" type="revolute">
<parent>base</parent>
<child>left_wheel</child>
<axis>
<xyz>0 1 0</xyz>
</axis>
<joint name="right_wheel" type="revolute">
<child>right_wheel</child>
<axis>
<xyz>0 1 0</xyz>
</axis>
<plugin name="differential_drive_controller" filename="libgazebo_ros_diff_drive.so">
<alwaysOn>true</alwaysOn>
<leftJoint>left_wheel</leftJoint>
<rightJoint>right_wheel</rightJoint>
<wheelSeparation>0.5380</wheelSeparation>
<wheelDiameter>0.2410</wheelDiameter>
<torque>20</torque>
<robotBaseFrame>base_footprint</robotBaseFrame>
while lauching the simulator with modified sdf file getting errors
Error [parser.cc:697] XML Element[sensor],child of element[model] not defined in SDF.
Ignoring.model]
Error [parser.cc:688] Error reading element <model>
Error [parser.cc:348] Unable to read element <sdf>
Error: Could not find the 'robot' element in the xml file
at line 81 in /build/buildd/urdfdom-0.2.10+dfsg/urdf_parser/src/model.cpp
Error [parser_urdf.cc:2608] Unable to call parseURDF on robot model
Error [parser.cc:299] parse as old deprecated model file failed.
Error [World.cc:1527] Unable to read sdf string[<sdf version="1.4"><model nnamame="swarmb....
same for each bot and finally getting status: [swarmbot0/create_model-5] process has finished cleanly
Does anyone know what am I doing wrong? I'm using gazebo 2.2 and ros-indigo.
Thanks in advance!
Asked by Aman_singh on 2015-05-31 08:17:11 UTC
Hi, I pushed the sonar plugin from the PAL domain to the official ROS Gazebo plugins. The test should give you a good enough hint for confiruging it on your robot: https://github.com/ros-simulation/gazebo_ros_pkgs/blob/jade-devel/gazebo_plugins/test/test_worlds/gazebo_ros_range.world
OR have a look at the URDF of PMB2 (from PAL Robotics): The corresponding URDF files to use the plugin with a macro: https://github.com/pal-robotics/pmb2_robot/blob/indigo-devel/pmb2_description/urdf/sensors/range.urdf.xacro https://github.com/pal-robotics/pmb2_robot/blob/indigo-devel/pmb2_description/urdf/sensors/range.gazebo.xacro
and the place where it gets deployed: https://github.com/pal-robotics/pmb2_robot/blob/indigo-devel/pmb2_description/urdf/base/base.urdf.xacro#L124
Hope this helps!
Asked by Bence Magyar on 2016-02-05 13:05:21 UTC
