Help to work on Gazebo 5.0 for a newbie in Simulation
asked 2015-06-17 02:25:23 -0600
RavitejaG gravatar image
updated 2015-06-17 02:28:04 -0600
Hallo,
Firstly sorry If I talk any wrong, I never worked in Gazebo Simulation or similar kind of projects. I am using ros(Indigo) as middleware for my project. Now I would like to work on Gazebo 5.0 which is supported by ros jade distro, I installed ros jade parallel with indigo. I couldn't able to understand even beginner tutorials in gazebosim.org tutorials, could any one please suggest me how to work on gazebo.
Thanks for reading.
answered 2015-06-17 04:10:40 -0600
niall gravatar image
There are a number of threads explaining exactly this. I would recommend only diverting from default package configurations if you are really missing something. Having 2 versions of ROS will probably complicate things if you're just starting to learn.
If you don't need Gazebo5, simply install Indigo which includes Gazebo2 with sudo apt-get install ros-indigo-desktop-full.
If you really need Gazebo5, do the same (install ROS Indigo) and then remove gazebo2 and install gazebo5 and gazebo5 wrappers. Check this thread: http://answers.gazebosim.org/question/8598/how-to-install-ros-indigo-gazebo-ros-control-with/. There's an official page as well but this one doesn't include any step by step manual; it's here: http://answers.gazebosim.org/question/8598/how-to-install-ros-indigo-gazebo-ros-control-with/
As for understanding the beginner tutorials, the step after installation in the tutorials is Getting Started, did you follow that and then continue on to Build a Robot? Maybe you can be more clear on what you don't understand or what you plan to achieve?
Asked: 2015-06-17 02:25:23 -0600
Seen: 181 times
Last updated: Jun 17 '15
