Running gzserver hangs on
Hi. I have Ubuntu 14.04.2 LTS, and just installed ROS jade which comes gazebo. When I run the standard gazebo
command, I get the gazebo gui, with a black screen instead of a 3d rendering. I can press buttons but they don't do anything and the simulation time is not running. And gzclient uses 100% CPU.
Because this didn't work I tried running gzserver --verbose
and then in a different terminal gzclient --verbose
When I do this I get the same result. I have inspected the logs, and can't find any
mention of the issue there. Because of this I am now stuck. I don't know where to debug next to find the issues? Any help would be greatly appreciated.
The different log files say this:
gzclient
Gazebo multi-robot simulator, version 5.0.1
Copyright (C) 2012-2015 Open Source Robotics Foundation.
http://gazebosim.org
(1435005457 956425158) [Msg] Waiting for master.
(1435005457 965050593) [Msg] Connected to gazebo master @ http://127.0.0.1:11345
(1435005457 965192387) [Msg] Publicized address: 192.168.1.5
(1435005458 966678428) [Wrn] [gazebo.cc:186] Waited 1seconds for namespaces.
(1435005459 968140729) [Wrn] [gazebo.cc:186] Waited 1seconds for namespaces.
(1435005460 969379185) [Wrn] [gazebo.cc:186] Waited 1seconds for namespaces.
(1435005461 970625836) [Wrn] [gazebo.cc:186] Waited 1seconds for namespaces.
(1435005462 971813569) [Wrn] [gazebo.cc:186] Waited 1seconds for namespaces.
(1435005463 973052910) [Wrn] [gazebo.cc:186] Waited 1seconds for namespaces.
(1435005464 974319177) [Wrn] [gazebo.cc:186] Waited 1seconds for namespaces.
(1435005465 975521944) [Wrn] [gazebo.cc:186] Waited 1seconds for namespaces.
(1435005466 976826511) [Wrn] [gazebo.cc:186] Waited 1seconds for namespaces.
(1435005467 978346401) [Wrn] [gazebo.cc:186] Waited 1seconds for namespaces.
(1435005468 979905050) [Err] [gazebo.cc:191] Waited 11 seconds for namespaces. Giving up.
(1435005468 980364818) Loaded .ini file from: "/home/lysgaard/.gazebo/gui.ini"
(1435005470 155222702) [Err] [Node.cc:98] No namespace found
(1435005471 183807127) [Err] [Node.cc:98] No namespace found
(1435005472 199489304) [Err] [Node.cc:98] No namespace found
(1435005473 387903100) [Err] [Node.cc:98] No namespace found
(1435005474 389467828) [Err] [Node.cc:98] No namespace found
(1435005475 390944483) [Err] [Node.cc:98] No namespace found
(1435005476 392562234) [Err] [Node.cc:98] No namespace found
(1435005477 393977301) [Err] [Node.cc:98] No namespace found
(1435005478 395705302) [Err] [Node.cc:98] No namespace found
(1435005479 397314823) [Err] [Node.cc:98] No namespace found
(1435005480 398751516) [Err] [Node.cc:98] No namespace found
(1435005481 402911076) [Err] [Node.cc:98] No namespace found
(1435005481 841306550) No spacenav daemon found. Spacenav functionality is disabled
gzserver
(1435005457 945789775) [Msg] Waiting for master.
(1435005457 954908186) [Msg] Connected to gazebo master @ http://127.0.0.1:11345
(1435005457 955031259) [Msg] Publicized address: 192.168.1.5
(1435005458 55868827) [Wrn] [ModelDatabase.cc:334] Getting models from[http://gazebosim.org/models/]. This may take a few seconds.
ogre.log
22 ...
It seems that gzserver is busy with something. What if you wait for it to finish its work?
I agree that something is busy, but I do not understand what it is busy doing. gzserver uses 0% CPU, read and writes nothing to neither disk nor network. How can I debug this?
