Gazebo plugin: unable to use world ptr in service
I am trying to make a plugin which creates a service that can run Gazebo for a specific number of physics loops.
So, I made this:
#include <rl_gazebo/run_physics.h>
#include <std_msgs/String.h>
namespace gazebo {
GazeboRunPhysicsPlugin::GazeboRunPhysicsPlugin() { }
GazeboRunPhysicsPlugin::~GazeboRunPhysicsPlugin() {
node_handle_->shutdown();
delete node_handle_;
void GazeboRunPhysicsPlugin::Load(physics::WorldPtr _world, sdf::ElementPtr _sdf) {
// Make sure the ROS node for Gazebo has already been initialized
if (!ros::isInitialized()) {
ROS_FATAL_STREAM("A ROS node for Gazebo has not been initialized, unable to load plugin. "
<< "Load the Gazebo system plugin 'libgazebo_ros_api_plugin.so' in the gazebo_ros package)");
return;
world_ = _world;
node_handle_ = new ros::NodeHandle;
service_ = node_handle_->advertiseService("run_physics_loops", &GazeboRunPhysicsPlugin::RunPhysicsLoops, this);
bool RunPhysicsLoops(rl_msgs::RunPhysicsLoops::Request &req,
rl_msgs::RunPhysicsLoops::Response &res) {
int nloops = req.num_loops;
world_->RunBlocking(nloops); // ERROR Here
return true;
GZ_REGISTER_WORLD_PLUGIN(GazeboRunPhysicsPlugin)
} // namespace gazebo
I get a compilation error at the point world_->RunBlocking(nloops);
which says:
.../src/run_physics.cc: In function ‘bool gazebo::RunPhysicsLoops(rl_msgs::RunPhysicsLoops::Request&, rl_msgs::RunPhysicsLoops::Response&)’:
.../src/run_physics.cc:36:3: error: ‘world_’ was not declared in this scope
What i am trying to do ...
I have a ros node which has it's own main loop - and in each oop of that I want to run gazebo's physics loop 10 (for example) times. I was using the ros services/topics to communicate with gazebo because I am using hectorquadrotor - which requires gazebo to be run using `gazeboros`.
Hence, I cannot make a gazebo server inside my rosnode - and need it to be run separately. So, I need a ros-service which should be able to call the line world->runBlocking(10)
. After a little digging I found a plugin can do this and now am trying to make one.
Asked by AbdealiJK on 2015-06-26 22:18:16 UTC
