Cannot launch Gazebo2.2.3
i have gazebo2.2.3 installed along with ROS indigo, when i try to run gazebo with gazebo
i received following result
Gazebo multi-robot simulator, version 2.2.3
Copyright (C) 2012-2014 Open Source Robotics Foundation.
http://gazebosim.org
Msg Waiting for master.Gazebo multi-robot simulator, version 2.2.3
Msg Publicized address: 172.27.138.171
robotics@robotics-desktop:~$
After some research i executed gzserver
and got the below result
Similarly for gzclient
i got
Msg Waiting for master..............................
Error [ConnectionManager.cc:116] Failed to connect to master in 30 seconds.
Error [gazebo.cc:59] Unable to initialize transport.
Error [gazebo.cc:203] Unable to setup Gazebo
Some of my searches telling this is issue related to graphics card so below is my graphic card details
00:02.0 VGA compatible controller [0300]: Intel Corporation 4 Series Chipset Integrated Graphics Controller [8086:2e32] (rev 03) (prog-if 00 [VGA controller])
Subsystem: Intel Corporation Device [8086:d613]
Flags: bus master, fast devsel, latency 0, IRQ 44
Memory at d0000000 (64-bit, non-prefetchable) [size=4M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f140 [size=8]
Expansion ROM at <unassigned> [disabled]
Capabilities: <access denied>
Kernel driver in use: i915
I am using ubuntu 14.04, ROS indigo, Gazebo2.2.3, how to get arround this issue?
Asked by KishoreKumar P on 2015-08-12 01:53:27 UTC
