ODE friction parameters and max_vel parameter in SDF format.
Hello! I'm trying to understand how the parameters that I set in <ode><friction> and <ode><contacts><max_vel> influence the simulation.
I build a basic gripper and I wanted to set the maximum friction on the gripper surface, so I put the following parameters in my SDF:
<surface>
<friction>
<ode>
<mu>1</mu>
<mu2>1</mu2>
</ode>
</friction>
<contact>
<ode>
<max_vel>0.0</max_vel>
</ode>
</contact>
</surface>
` The questions are the following:
- What exactly represent mu an mu2? I have read in the ODE manual that they are Coulomb friction parameters, so I would expected that mu is the static friction parameter and mu2 the dynamic one, but in the manual and in the SDF documentation there are some references to different directions...
- Why there still subsist a relative motion between my gripper and the object?
Asked by Formigola on 2015-08-20 14:28:50 UTC
- You can read about
muandmu2on the ODE user guide. The difference is not about static vs dynamic, but about direction:muacts on directionfdir1andmu2acts perpendicular to that and to the contact normal.
If fdir1 is not specified in the SDF, "automatically compute friction direction 1 to be perpendicular to the contact normal (in which case its resulting orientation is unpredictable)."
If you want contact that never slips, you must set mu to infinity (<mu>Inf</mu>) as explained in the same link.
- max_vel, as explained in the Gazebo API, is not about surfaces sliding against each other (like friction), but about interpenetration: "Maximum interpenetration error correction velocity. If set to 0, two objects interpenetrating each other will not be pushed apart."
Asked by chapulina on 2015-08-21 11:08:41 UTC
