The oscillation of a joint with no command and zero gains
I have loaded my robot into Gazebo. This robot is 6 DOF. You can see the files from here. I have tuned PID parameters of ros_control for five joints. But, tuning joint 4 is not really easy. The behavior of joint 4 is strange too. When the input is in the following range (1.5<$input$<2 and -2<$input$<-1.5) the joint moves correctly. Otherwise, the error signal oscillates and the process_value signal does not oscillate. The reason to this issue is not clear to me.
Would you please give me a hint how to do that.
To run the code easily please enter the following lines:
1) run gazebo:
roslaunch denso_gazebo denso_world.launch
2) run rqt to show the figures and commands:
roslaunch denso_control denso_rqt.launch
The distro of my ROS is indigo running on Ubuntu 14.04.
Thank you.
Asked by MahsaP on 2015-09-03 12:00:54 UTC
I found the problem. It had to do with the max and min of the joint.
Asked by MahsaP on 2015-10-05 06:56:32 UTC
