Gazebo crashes when inserting Camera (in Virtual Machine with Ubuntu Vivid + ROS Jade)
asked 2015-09-12 21:00:15 -0600
jura gravatar image
updated 2015-09-14 02:00:42 -0600
Gazebo crashes when inserting Camera (in Virtual Machine with Ubuntu Vivid + ROS Jade):
gzserver: /build/buildd/ogre-1.9-1.9.0+dfsg1/OgreMain/src/OgreRenderSystem.cpp:546: virtual void Ogre::RenderSystem::setDepthBufferFor(Ogre::RenderTarget*): Assertion `bAttached && "A new DepthBuffer for a RenderTarget was created, but after creation" "it says it's incompatible with that RT"' failed.
How to solve this issue ?
@ubuntu:~$ gazebo --verbose
Gazebo multi-robot simulator, version 5.0.1
Copyright (C) 2012-2015 Open Source Robotics Foundation.
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 192.xxx.yyy
[Err] [InsertModelWidget.cc:277] Missing model.config for model
"/usr/share/gazebo-5.0/models/icons"
[Wrn] [Publisher.cc:131] Queue limit reached for topic
/gazebo/default/physics/contacts, deleting message. This warning is printed only once.
gzclient: /build/buildd/ogre-1.9-1.9.0+dfsg1/OgreMain/src/OgreRenderSystem.cpp:546:
@ubuntu:~$
Can you run gazebo with the --verbose option and post the full console output?
scpeters gravatar imagescpeters ( 2015-09-14 00:48:34 -0600 )edit
@scpeters, I inserted the output of --verbose into the question.
jura gravatar imagejura ( 2015-09-14 01:45:17 -0600 )edit
which VM are you using? Parallels 10 works perfectly for me with gazebo 5 (gazebo 2.2 not so much)
l0g1x gravatar imagel0g1x ( 2015-09-24 14:04:56 -0600 )edit
Hi @I0g1x, I am using VMware Workstation 12 Player.
jura gravatar imagejura ( 2015-09-24 15:11:41 -0600 )edit
answered 2016-04-09 13:00:51 -0600
migelk gravatar image
This is related to z ordering when using camera and gazebo on a virtual machine see this issue for a possible fix.
Asked: 2015-09-12 21:00:15 -0600
Seen: 7,295 times
Last updated: Sep 14 '15
