Clarification on moving joint with model plugin
This is my first week with Gazebo. The tutorials are clear (except for my dearth of C++ knowledge) but now that I'm working to move out on my own things are getting cloudy. I made a model comprising two boxes and a revolute joint. The file one_r_test.world loads this model. A plugin is "loaded" (?) in model.sdf and that plugin, ModelControl, comes from model_push.cc in the "Model plugins" tutorial (http://gazebosim.org/tutorials?tut=plugins_model&cat=write_plugin), which uses SetLinearVel to move a box. I can get this same behavior out of model_control.cc if I just copy the tutorial code (and change the plugin name as appropriate), but that's not what I want. I'm seeking to eventually simulate joint control of robotic manipulators and what's not working in this basic simulation is my attempt to move the model joint via the ModelControl plugin. It moves in the GUI if I set the velocity (or torque) that way. The model_control.cc code is pasted below in hopes that you can identify a problem.
I used SetParam based on this answer: http://answers.gazebosim.org/question/8371/kobukiturtlebot-doesnt-move-when-given-velocity-commands-in-gazebo-5/?answer=8377#post-id-8377.
model_control.cc
#include "boost/bind.hpp"
#include "gazebo/gazebo.hh"
#include "gazebo/physics/physics.hh"
#include "gazebo/common/common.hh"
#include "stdio.h"
// In the real file these quotes are greater-than and less-than but I
// don't know how to get that to show up in my question
namespace gazebo
  class ModelControl : public ModelPlugin
      this->model = _parent;
      // Store the pointers to the joints
      this->jointR1_ = this->model->GetJoint("r1");
      // simulation iteration.
      this->updateConnection = event::Events::ConnectWorldUpdateBegin(boost::bind(&ModelControl::OnUpdate, this, _1));
  public: void OnUpdate(const common::UpdateInfo & /*_info*/)
      // Apply a small linear velocity to the model.
      //this->model->SetLinearVel(math::Vector3(.03, 0, 0));
      // Apply angular velocity to joint
      this->jointR1_->SetParam("vel", 0, 99);
      this->jointR1_->SetParam("max_force", 0, 9999999999);
      double currAngle = this->jointR1_->GetAngle(0).Radian();
      printf("Current angle is \t %f\n", currAngle);
    // Maybe I want to keep track of time?
    common::Time last_update_time_;
    // Pointer to the model
    // Pointers to joints
    physics::JointPtr jointR1_;
  GZ_REGISTER_MODEL_PLUGIN(ModelControl)
edit: If I change
to
this->jointR1_->SetVelocity(0, 99);
then the joint moves (yes, very, very quickly). What's wrong with SetParam vs SetVelocity?
