Gazebo focussed questions on answers.ros
I know that there are also a ton of unanswered questions already here (I wish knew enough to answer them!).. but there are also a large number of Gazebo related questions on answers.ros that need the attention of this community.
http://answers.gazebosim.org/question/11966/gazebo-multiple-robot-and-ros_control-interfaces/
https://groups.google.com/forum/#!searchin/ros-sig-robot-control/sdf/ros-sig-robot-control/8BWZR7kUTy8/iACJQ3cqDwAJ
http://answers.ros.org/question/222829/gazebo-model-problems/
http://answers.ros.org/question/223196/using-gazebo_ros_control-with-sdf-instead-of-urdf/ (not really a solution/answer!)
http://answers.ros.org/question/221702/force-torque-sensor-simulation/
http://answers.ros.org/question/225420/ur5-gazebo-joint-position-controller/
http://answers.ros.org/question/223167/can-somebody-explain-me-the-relation-between-xacro-file-and-gazebo-file-and-whats-the-philosophy-behind-them/y-behind-them/
http://robotics.stackexchange.com/questions/6811/mobile-robot-behaving-strangely-while-rotating-and-reversing-in-gazebo-simulatio
Gazebo focussed focused questions on answers.rosanswers.ros and other social media
I know that there are also a ton of unanswered questions already here (I wish knew enough to answer them!).. but there are also a large number of Gazebo related questions on answers.ros that need the attention of this community.community. It almost makes it seem that there's a gap/need in the tutorials since there are reoccurring themes that appear to be still unaddressed.
http://answers.ros.org/question/209144/read-the-sensor-data-of-gazebo-sdf-model-in-ros/
Gazebo focused focussed questions on answers.ros and other social mediaanswers.ros
I know that there are also a ton of unanswered questions already here (I wish knew enough to answer them!).. but there are also a large number of Gazebo related questions on answers.ros that need the attention of this community. It almost makes it seem that there's a gap/need in the tutorials since there are reoccurring themes that appear to be still unaddressed.
http://answers.ros.org/question/45465/gazebo-sdf-kinect/
What can be done to address the following issue?
A tutorial! http://www.theconstructsim.com/create-a-ros-sensor-plugin-for-gazebo/
