Common::PID settings (joint unable to lift a weight)
Hello everybody,
I am trying to simulate a robot which must lift an object from the ground.
I use a prismatic joint controlled with a plugin. I use JointController class and functions like SetPositionTarget to control it.
When I send a position without an object to lift, the target position is reached. But when I have an object to lift, the target position is not reached. I tried to tune PID values but even with very high values the target position is not reached. I checked the effort limit and the effort sent to the link is ten time lower to the limit (so no limitation from the model).
Is it just a pid settings problem or is there another way to do it.
Thanks in advance
