Am I right that there is no fixed
joint type in SDF similar to one in URDF? So how should I implement one?
In one of the tutorials Hokuyo laser is attached to a mobile platform with revolute
joint, but with zero limits:
<joint name="hokuyo_joint" type="revolute">
<child>hokuyo::link</child>
<parent>chassis</parent>
<axis>
<xyz>0 0 1</xyz>
<limit>
<upper>0</upper>
<lower>0</lower>
</limit>
</axis>
Same approach is used in Simple Arm
model, to attach it to the ground.
Although it seems ok, but there is an extra joint control on Joints
pane which of course does not control anything. Also there is an extra coordinate frame marker in scene.
So is it the only way to implement fixed joints?
