Jpeg file make Gazebo die
I'm currently re-using some old code developed under ROS Electric with ROS Fuerte. Especially, I'm spawning in Gazebo a customized wall+photo environment described in a urdf file. I defined my own Material, for example :
material Siri/sima-south-left
 technique
        pass
            lighting off
            ambient 1 1 1 1
            diffuse 1 1 1 1
            specular 0 0 0 0
            emissive 0 0 0
            alpha_rejection greater 128
            depth_write on
            texture_unit
                tex_coord_set 0
                colour_op modulate
Around every wall spawn correctly with the photo applied as texture. But on two photos (sima-south-left.jpg and sime-south-right.jpg), the texture isn't found and Gazebo die with error :
Warning [Visual.cc:689] Unable to get Material[Gazebo/WhiteEmissive] for Geometry[laby::Mur2::Mur2_geom_visual. Object will appear white
Warning [Visual.cc:745] Unable to set Material[laby::Mur20::Mur20_geom_visual_MATERIAL_Isir/sima-south-left] to Geometry[laby::Mur20::Mur20_geom_visual. Object will appear white.
Qt has caught an exception thrown from an event handler. Throwing exceptions from an event  handler is not supported in Qt. You must reimplement QApplication::notify() and catch all exceptions there.
terminate called after throwing an instance of 'Ogre::RenderingAPIException'
  what():  OGRE EXCEPTION(3:RenderingAPIException): Zero sized texture surface on texture sima-south-left.jpg face 0 mipmap 0. Probably, the GL driver refused to create the texture. in GLTexture::_createSurfaceList at /tmp/buildd/ros-fuerte-visualization-common-1.8.4/debian/ros-fuerte-visualization-common/opt/ros/fuerte/stacks/visualization_common/ogre/build/ogre_src_v1-7-3/RenderSystems/GL/src/OgreGLTexture.cpp (line 406)
/opt/ros/fuerte/stacks/simulator_gazebo/gazebo/scripts/gui : ligne 2 : 22405 Abandon                 (core dumped) `rospack find gazebo`/gazebo/bin/gzclient -g `rospack find gazebo`/lib/libgazebo_ros_paths_plugin.so
[gazebo_gui-2] process has died [pid 22402, exit code 134, cmd /opt/ros/fuerte/stacks/simulator_gazebo/gazebo/scripts/gui __name:=gazebo_gui __log:=/home/renaudo/.ros/log/7871d046-7465-11e2-8470-00259079bc9a/gazebo_gui-2.log].
log file: /home/renaudo/.ros/log/7871d046-7465-11e2-8470-00259079bc9a/gazebo_gui-2*.log
I don't get why two specific images are making Gazebo die. Are there max/min size on texture we can use ? All images are in jpg and located in the same folder. This code was working with Electric.
Any advice would be welcome. Thanks for reading.
click to hide/show revision 2
Giving more information
 technique
        pass
            lighting off
            ambient 1 1 1 1
            diffuse 1 1 1 1
            specular 0 0 0 0
            emissive 0 0 0
            depth_write on
            texture_unit
                tex_coord_set 0
                colour_op modulate
EDIT : I tried with some others random pictures from internet, and I have no problem to map them on walls ... that's quite strange that two specific pictures are making gazebo crash ...
click to hide/show revision 3
answering the question and marking as 'solved'
[solved] Jpeg file make Gazebo die
 technique
        pass
            lighting off
            ambient 1 1 1 1
            diffuse 1 1 1 1
            specular 0 0 0 0
            emissive 0 0 0
            depth_write on
            texture_unit
                tex_coord_set 0
                colour_op modulate
