Unable to run gazebo from the terminal
Hello guys, I installed gazebo (gazebo2) with ros. But when i tried to run i, writing "gazebo on the terminal", it shows me this:
almosca@pcen35132:~$ gazebo-2.2.6
Gazebo multi-robot simulator, version 2.2.6
Copyright (C) 2012-2014 Open Source Robotics Foundation.
http://gazebosim.org
Msg Waiting for masterMsg Waiting for master
sg Connected to gazebo master @ http://127.0.0.1:1134532m
sg Publicized address: 188.184.5.12
32mMsg Publicized address: 188.184.5.12
Warning [parser.cc:556] The manifest.xml for a model is deprecated. Please rename manifest.xml to model.config. terminate called after throwing an instance of 'std::bad_alloc' what(): std::bad_alloc
could some one help me ?? thanks
std::bad_alloc
