I am evaluating the physics engine of Gazebo and am having a strange problem getting a simple rotary inverted pendulum to work. My analytical solution shows that the natural period should be less than 1 second, but in the simulation it has a period of around of 5 seconds. The horizontal support arm is not moving in reaction to the pendulum swinging. I am applying a moment to the pendulum using the GUI to cause it to swing to observe the period. I have placed the SDF file on pastebin:
http://pastebin.com/EJK1AANe
Note that the meshes have been replaced with basic geometry for simplicity. The inertial parameters were generated using a rough Solidworks model of a brass pendulum with an aluminum arm.
Is there a problem with the SDF file causing the weird simulation result?
