How to Control Pioneer2DX in Gazebo...?
So I am using gazebo to simulate a pioneer2dx model, however I can't find a good documentation on how to control it properly. Right now my plugin uses the SetLinerVel function to move the robot, however this just pushed the robot along. I want to know how to be able to control the actual wheels of the robot (i.e. set the angular velocity of the hinges). Is there a way to do this? Also is there a way to get the sensor values from the robot? Thanks.
UPDATE
Here is my plugin c++ code:
#include <boost/bind.hpp>
#include <gazebo/gazebo.hh>
#include <stdio.h>
namespace gazebo
class PioneerProg : public ModelPlugin
  this->model = _parent;
  // simulation iteration.
      boost::bind(&PioneerProg::OnUpdate, this, _1));
public: void OnUpdate(const common::UpdateInfo & /*_info*/)
  // Apply a small linear velocity to the model.
  //this->model->SetLinearVel(math::Vector3(0.06, 0, 0));
joints[LEFT_FRONT_WHEELING] = this->parent->GetJoint(left_wheel_hinge);
joints[LEFT_FRONT_WHEELING]->SetParam("fmax", 0, torque);
joints[LEFT_FRONT_WHEELING]->SetParam("vel", 0, wheel_data_[LEFT_FRONT_WHEELING]/(wheel_diameter_/2.0));
// Pointer to the model
GZ_REGISTER_MODEL_PLUGIN(PioneerProg)
And here is my world file xml code:
<?xml version="1.0" ?>
<sdf version="1.5">
<world name="default">
        <uri>model://sun</uri>
    <!-- A ground plane -->
    <!-- Generate Population -->
    <population name="pioneer_population1">
        <!-- Define the population model type -->
        <model name="pioneer1">
                <static>false</static>
                <uri>model://pioneer2dx</uri>
            <plugin name="pioneer_prog" filename="libpioneer_prog.so"/>
        <!-- Center spawn around (0,0,0) with orientation <0,0,0> -->
        <pose>0 0 0 0 0 0</pose>
        <!-- Size of spawn area -->
            <size>8 8 0.01</size>
        <!-- world_builder will insert this line based on user params -->
        <!-- MODEL_COUNT -->
        <!-- /MODEL_COUNT -->
        <!-- Define how the models will be distributed -->
        <!-- Distribution types: random, uniform, grid, linear-x,
        liner-y, linear-z -->
        <distribution>
            <type>random</type>
        </distribution>
    </population>
</world>
