GAZEBO plugin subscribe to ROS topic
Greetings, I have some problems making a GAZEBO plugin and a ROS node communicate. The ROS node pubblishes correctly the message on the topic, but the plugin isn't able to acces them.
This is the code of the plugin:
// Initialize node
node = transport::NodePtr(new transport::Node());
// Subscribe to the control node
node->Init("gazebo/quetzalcoatl");
std::cout << "Subscribing to " << "~/quetzalcoatl/cmdVelocity" << " topic" << std::endl;
commandSubscriber = node->Subscribe("~/quetzalcoatl/cmdVelocity", &SkidSteer::updateVelocity, this);
std::cout << "Subscribed to " << commandSubscriber << std::endl;
// Listen to the update event, this event is broadcast every simulation iteration
boost::bind(&SkidSteer::OnUpdate, this, _1));
This is the code of the ROS node which pubblishes the message:
while (ros::ok())
    ROS_INFO("Node '%s' sending the %d message", ros::this_node::getName().c_str(), count);
    // Update the velocities
    linearVelocity = 10 + count / 100;
    angularVelocity = 0;
    // Fill the message
    cmdVelocityMsg.linearVelocity = linearVelocity;
    cmdVelocityMsg.angularVelocity = angularVelocity;
    cmdVelocityMsg.moveUp = moveUp;
    cmdVelocityMsg.moveDown = moveDown;
    cmdVelocityMsg.moveLeft = moveLeft;
    cmdVelocityMsg.moveRigth = moveRigth;
    cmdVelocityPub.publish(cmdVelocityMsg);
    ros::spinOnce();
    // Sleep untill next loop, Gazebo must be running or it won't work
    loopRate.sleep();
    // ROS_INFO("Sleeped");
    ++count;
This is the message used by the plugin:
package quetzalcoatlMsgs.msgs;
message cmdVelocity
    required float linearVelocity = 1;
    required float angularVelocity = 2;
    required bool moveUp = 3;
    required bool moveDown = 4;
    required bool moveLeft = 5;
    required bool moveRigth = 6;
This is the message used by the node:
float32 linearVelocity
float32 angularVelocity
bool moveUp
bool moveDown
bool moveLeft
bool moveRigth
What I'm doing wrong? Also it is correct to declare two different messages, one for the node and one for the plugin, which refer to the same topic?
