Plugin tutorial: Plugin doesn't start
I'm doing the Velodyne LiDAR plugin tutorial (http://gazebosim.org/tutorials?cat=guided_i&tut=guided_i5), but I can't get Gazebo to recognize the plugin. I have copied the code from steps 2-4 and successfully built it using cmake and make, but when I run the scene using
cd ~/velodyne_plugin/build
gazebo ../velodyne.world
Gazebo just starts the scene without outputting anything to the terminal. I also tried adding the code supposed to spin the joint, as in step 5, with the same result. I even tried removing the plugin library file (libvelodyne_plugin.so) that I built altogether, while still having the line
<plugin name="velodyne_control" filename="libvelodyne_plugin.so"/>
in my .world-file and Gazebo still launches the scene just fine. I also tried adding another model (the Cessna air plane) to the .world-file, and that one appears as it should.
Any ideas?
Any ideas?
Plugin tutorial: Plugin doesn't startGazebo starts but not plugin
Any ideas?
EDIT: My OS is Ubuntu 16.04, and I run Gazebo version 7.0.0
Plugin tutorial: Gazebo starts but not plugin
Any ideas?
EDIT2: Using the --verbose tag gives the following output:
~/Developer/Gazebo/velodyne_plugin/build$gazebo ../velodyne.world --verbose
Gazebo multi-robot simulator, version 7.0.0
Copyright (C) 2012-2016 Open Source Robotics Foundation.
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.121.123
[Err] [Plugin.hh:165] Failed to load plugin libvelodyne_plugin.so: libvelodyne_plugin.so: cannot open shared object file: No such file or directory
