Removing pinning from the hip joint
(Forwarded from DRC Forum)
Hi, I understand that balancing is still not implemented, but if I'd wish to implement it, how could I remove the pinning so that the robot would actually fall to the ground. I remember there should be some static tag in the urdf file of the robot (/usr/share/drcsim-1.0/ros/drc_robot_utils ?) but was not able to locate it. Thanks.
Hi, I understand that balancing is still not implemented, but if I'd wish to implement it, how could I remove the pinning so that the robot would actually fall to the ground. I remember there should be some static tag in the urdf file of the robot (/usr/share/drcsim-1.0/ros/drc_robot_utils (/usr/share/drcsim-1.0/ros/drc_robot_utils ?) but was not able to locate it. Thanks.
