Can i install the atlas robot for test, without installing the drcsim? When i installed the drcsim previously my gazebo version was changed because of which i had problem running gazebo ros package. So is their any other methode?
![]() | 1 | initial version |
Can i install the atlas robot for test, without installing the drcsim? When i installed try this line : hg clone https://bitbucket.org/osrf/drcsim
, it is not working, in terminal after this message:
destination directory: drcsim
requesting all changes
adding changesets
adding manifests
adding file changes
nothing happens, inside the drcsim previously folder i cant see any file or folder, its just empty. Is this happening because my wifi is working slow, or else. I have already installed ros indigo, gazebo version was changed because of which i had problem running gazebo ros package. So is their any other methode?7 and gazebo_ros package.
