TransformBroadcaster and Gazebo plugins
Hi, I have been wanting to get various Gazebo plugins working with ROS, starting with Differential Drive plugin. I would like to get sdf files working with gazebo plugins. I had some small success getting Twist messages to change joint states, but now I want to get odometry working. I have just pieced together what I could from erratic_gazebo_plugins and the DRCSim plugins.
DiffDriveROSPlugin.cpp
Any time I want to declare a TransformBroadcaster type I get this error: gazebo: symbol lookup error:
this->transformBroadcaster = new tf::TransformBroadcaster();
/home/thelegace/fuerte_workspace/ales_robot/ales_msgs/lib/libDiffDriveROSPlugin.so: undefined symbol: _ZN2tf20TransformBroadcasterC1Ev
If I comment out the transform broadcaster instantiation my plugin loads fine. The pioneer2dx model file.
Please let know if there any issue with the code or anything else that I am doing.
Hi, I have been wanting to get various Gazebo plugins working with ROS, ROS using SDF format, starting with Differential Drive plugin. I would like to get sdf files working with gazebo plugins. I had some small success getting Twist messages to change joint states, but now I want to get odometry working. I have just pieced together what I could from erratic_gazebo_plugins and the DRCSim plugins.
Any time I want to declare a TransformBroadcaster type I get this error: this->transformBroadcaster = new tf::TransformBroadcaster();
Hi, I have been wanting to get various Gazebo plugins working with ROS using SDF format, starting with Differential Drive plugin. I had some small success getting Twist messages to change joint states, but now I want to get odometry working. I have just pieced together what I could from erratic_gazebo_plugins and the DRCSim plugins.
Any time I want to declare a TransformBroadcaster type I get this error: this->transformBroadcaster = new tf::TransformBroadcaster();error:
