Hello everybody,
I am moving a box using the animation system (KeyFrame,...). I would like to output some datas like the model's position and speed. I have created a model plugin.
No problem for the position but I have some trouble for the speed.
The GetWorldLinearVel function seems to return a 0.0 value for x, y and z attributes.
Here is the code to get the speed datas :
custom_msgs::msg_command speed_msg;
speed_msg.header.stamp = ros::Time::now();
speed_msg.header.frame_id = m_model->GetName();
auto linear = m_model->GetWorldLinearVel();
speed_msg.yaw_rate.data = m_model->GetWorldAngularVel().z;
ROS_INFO("speed data");
ROS_INFO("x: %lf", linear.x);
ROS_INFO("y: %lf", linear.y);
ROS_INFO("z: %lf", linear.z);
