Changing physics engine through URDF
Hi everybody
Would you please tell me that how can I change physics engine (eg. ODE, Bullet , ...) through launch file and URDF. I have created a package that contains one xacro file (which is used to model and inverted pendulum) and two launch file that are as follow:
///////////////// Inverted_pendulum_world.launch //////////////// <launch>
<arg name="paused" default="false"/> <arg name="use_sim_time" default="true"/> <arg name="gui" default="true"/> <arg name="headless" default="false"/> <arg name="debug" default="false"/>
<include file="$(find gazebo_ros)/launch/empty_world.launch"> <arg name="debug" value="$(arg debug)"/> <arg name="gui" value="$(arg gui)"/> <arg name="paused" value="$(arg paused)"/> <arg name="use_sim_time" value="$(arg use_sim_time)"/> <arg name="headless" value="$(arg headless)"/> </include>
<node name="urdf_spawner" pkg="gazebo_ros" type="spawn_model" respawn="false" output="screen" args="-urdf -model inverted_pendulum -param robot_description"/>
</launch> gazebo 2.2 + Ubuntu 14.04 + ROS Indigo
Hi everybody
<launch>
  <!-- these are the arguments you can pass this launch file, for example paused:=true -->
default="false"/> <!-- We resume the logic in empty_world.launch --> <include file="$(find gazebo_ros)/launch/empty_world.launch"> <arg name="debug" value="$(arg debug)"/> debug)" /> <arg name="gui" value="$(arg gui)"/> gui)" /> <arg name="paused" value="$(arg paused)"/> <arg name="use_sim_time" value="$(arg use_sim_time)"/> <arg name="headless" value="$(arg headless)"/> </include>
</include> <!-- Load the URDF into the ROS Parameter Server --> <param name="robot_description" command="$(find xacro)/xacro.py '$(find ip_cloned)/urdf/inverted_pendulum.xacro'" /> <!-- Run a python script to the send a service call to gazebo_ros to spawn a URDF robot --> <node name="urdf_spawner" pkg="gazebo_ros" type="spawn_model" respawn="false" output="screen" output="screen" args="-urdf -model inverted_pendulum -param robot_description"/>
robot_description"/> </launch>
////////////////////Inverted_pendulum_gazebo_control.launch /////////////////
<launch>
  <!-- Launch Gazebo  -->
  <include file="$(find ip_cloned)/launch/inverted_pendulum_world.launch" />
  <!-- Load joint controller configurations from YAML file to parameter server -->
  <rosparam file="$(find ip_cloned)/config/inverted_pendulum_gazebo_control.yaml" command="load"/>
  <!-- load the controllers -->
  <node name="controller_spawner" pkg="controller_manager" type="spawner" respawn="false"
    output="screen" ns="/inverted_pendulum" args="joint_state_controller
                      joint1_position_controller"/>
  <!-- convert joint states to TF transforms for rviz, etc -->
    <remap from="/joint_states" to="/inverted_pendulum/joint_states" />
  </node>
</launch>
I'm using gazebo 2.2 + Ubuntu 14.04 + ROS Indigo Indigo
Thanks
Hi everybody
<launch>
    <arg name="debug" value="$(arg debug)" />
    <arg name="gui" value="$(arg gui)" />
</launch>
<launch>
  </node>
</launch>
Thanks
