Is it possible to add transparency property to a material?
Hi all!
I'm trying to model a glass wall for a robotics cell. Is there a way to set the material's transparency within a urdf model?
Thank you!!!
Hi all!
Thank you!!!
Is it possible to add transparency property to a material?an object?
Hi all!
Thank you!!!
EDIT:
Thank you Peter, your reply was very helpful. I solved the problem using GreyTransparent.
I have edited my urdf adding the following lines:
<gazebo reference="back_wall1">
    <material>Gazebo/GreyTransparent</material>
Anyway, I found that there are other colors in gazebo.materials
Is it possible to add transparency property to an object?
Hi all!
Thank you!!!
EDIT:
