Ever since I've upgraded to Gazebo 7, any LARGE mesh I use as a visual in a model file only partially loads. The majority of the polygons/shapes are missing when I load the model in Gazebo. I have opened the Collada files in other software and verified that the meshes are correct. Any ideas what might be causing the issue? These meshes used to work fine in previous versions of Gazebo.
