How to move a prismatic (or other) joint to negative limits?
When creating a prismatic joint between two links, it seems as though that initial distance between the links behaves as a "hard stop" for the joint.
If treating it like a spring, the initial position seems to be the "fully compressed" representation and all spring effects extend from that distance.
Is all this true? Does the "lower limit" = the initial distance between the links?
And if so, is there a way to work around this and move the joint lower than the lower limit (to bring the links closer together than their initial positions)?
(Note: This is an extension of this question.)
Example Code:
<model name='Pris_1'>
<link name='link_0'>
  <pose frame=''>2.7415 -3.31431 1.27606 -1.5708 -0 -0.37111</pose>
    <mass>1</mass>
      <ixx>0.145833</ixx>
      <iyy>0.145833</iyy>
      <izz>0.125</izz>
  <kinematic>1</kinematic>
  <visual name='visual'>
      <cylinder>
        <radius>0.003</radius>
        <length>0.1</length>
      </cylinder>
  <collision name='collision'>
    <laser_retro>0</laser_retro>
      <cylinder>
        <radius>0.0025</radius>
      </cylinder>
    <surface>
      <friction>
        <ode>
          <mu>1</mu>
          <mu2>1</mu2>
          <fdir1>0 0 0</fdir1>
          <slip1>0</slip1>
          <slip2>0</slip2>
        </ode>
        <torsional>
          <coefficient>1</coefficient>
          <patch_radius>0</patch_radius>
          <surface_radius>0</surface_radius>
          <use_patch_radius>1</use_patch_radius>
          <ode>
            <slip>0</slip>
          </ode>
        </torsional>
      </friction>
      <bounce>
        <threshold>1e+06</threshold>
      </bounce>
      <contact>
        <collide_without_contact>0</collide_without_contact>
        <collide_without_contact_bitmask>1</collide_without_contact_bitmask>
        <collide_bitmask>1</collide_bitmask>
        <ode>
          <soft_cfm>0</soft_cfm>
          <soft_erp>0.2</soft_erp>
          <kp>1e+13</kp>
          <kd>1</kd>
          <max_vel>0.01</max_vel>
          <min_depth>0</min_depth>
        </ode>
        <bullet>
          <split_impulse>1</split_impulse>
          <split_impulse_penetration_threshold>-0.01</split_impulse_penetration_threshold>
          <kp>1e+13</kp>
          <kd>1</kd>
        </bullet>
      </contact>
    </surface>
<model name='rope'>
  <pose frame=''>3.00263 -3.42589 1.02758 -3.0832 -0.749567 2.76636</pose>
  <link name='pivot'>
    <pose frame=''>0.4048 0 0 0 -0 0</pose>
      <mass>0.1</mass>
        <ixx>0.01</ixx>
        <iyy>0.01</iyy>
        <izz>0.01</izz>
    <collision name='pivot_collision'>
        <mesh>
          <scale>0.1 0.1 0.1</scale>
          <uri>model://ball.stl</uri>
        </mesh>
      <surface>
        <contact>
          <ode>
            <min_depth>0.005</min_depth>
          </ode>
        </contact>
        <friction>
          <ode>
            <mu>1</mu>
            <mu2>1</mu2>
          </ode>
          <torsional>
            <ode/>
          </torsional>
        </friction>
        <bounce/>
      </surface>
    <visual name='pivot_vis'>
        <mesh>
        </mesh>
    <kinematic>0</kinematic>
 <model name='cylinder'>
    <pose frame=''>5e-06 3e-06 0.5 1.5708 -0 0</pose>
      <mass>1</mass>
        <ixx>0.166667</ixx>
        <iyy>0.166667</iyy>
        <izz>0.166667</izz>
        <mesh>
          <uri>/home/.../cylinder.stl</uri>
          <scale>1 1 1</scale>
        </mesh>
        <mesh>
        </mesh>
      <surface>
        <friction>
          <ode>
            <mu>1</mu>
            <mu2>1</mu2>
            <slip1>0</slip1>
            <slip2>0</slip2>
          </ode>
          <torsional>
            <ode>
              <slip>0</slip>
            </ode>
          </torsional>
        </friction>
        <bounce>
        </bounce>
        <contact>
          <ode>
            <kp>1e+13</kp>
            <kd>1</kd>
          </ode>
          <bullet>
            <kp>1e+13</kp>
            <kd>1</kd>
          </bullet>
        </contact>
      </surface>
  <static>0</static>
  <allow_auto_disable>1</allow_auto_disable>
  <pose frame=''>2.74222 -3.31252 0.776355 -0.008957 -0.000714 -0.363118</pose>
<joint name='link_0_JOINT_0' type='revolute'>
  <parent>rod::link_0</parent>
  <child>cylinder::link_0</child>
  <pose frame=''>0 0 0.01 0 -0 0</pose>
  <axis>
    <xyz>0 0 1</xyz>
    <use_parent_model_frame>0</use_parent_model_frame>
    <limit>
      <lower>-1.79769e+308</lower>
      <upper>1.79769e+308</upper>
      <effort>-1</effort>
      <velocity>-1</velocity>
    </limit>
    <dynamics>
      <damping>0</damping>
      <friction>0</friction>
    </dynamics>
  </axis>
  <physics>
    <ode>
      <limit>
        <cfm>0</cfm>
        <erp>0.2</erp>
      </limit>
      <suspension>
        <cfm>0</cfm>
        <erp>0.2</erp>
      </suspension>
    </ode>
  </physics>
<joint name='link_0_JOINT_2' type='prismatic'>
  <parent>rope::pivot</parent>
  <axis>
    <xyz>0 0 1</xyz>
    <limit>
      <lower>-1e-05</lower>
      <upper>0.0001</upper>
      <effort>1</effort>
    </limit>
    <dynamics>
      <spring_reference>-1</spring_reference>
      <spring_stiffness>10</spring_stiffness>
    </dynamics>
  </axis>
  <physics>
    <ode>
      <limit>
        <cfm>0</cfm>
        <erp>0.8</erp>
      </limit>
      <suspension>
        <cfm>0</cfm>
        <erp>0.8</erp>
      </suspension>
    </ode>
  </physics>
<static>0</static>
Example Code:
name='rod'>
    <mass>1</mass>
      <ixx>0.145833</ixx>
      <iyy>0.145833</iyy>
      <izz>0.125</izz>
      <cylinder>
      </cylinder>
      <cylinder>
      </cylinder>
    <surface>
      <friction>
        <ode>
          <mu>1</mu>
          <mu2>1</mu2>
          <slip1>0</slip1>
          <slip2>0</slip2>
        </ode>
        <torsional>
          <ode>
            <slip>0</slip>
          </ode>
        </torsional>
      </friction>
      <bounce>
      </bounce>
      <contact>
        <ode>
          <kp>1e+13</kp>
          <kd>1</kd>
        </ode>
        <bullet>
          <kp>1e+13</kp>
          <kd>1</kd>
        </bullet>
      </contact>
    </surface>
<model name='rope'>
  <link name='pivot'>
      <mass>0.1</mass>
        <ixx>0.01</ixx>
        <iyy>0.01</iyy>
        <izz>0.01</izz>
        <mesh>
        </mesh>
      <surface>
        <contact>
          <ode>
          </ode>
        </contact>
        <friction>
          <ode>
            <mu>1</mu>
            <mu2>1</mu2>
          </ode>
          <torsional>
            <ode/>
          </torsional>
        </friction>
        <bounce/>
      </surface>
        <mesh>
        </mesh>
      <mass>1</mass>
        <ixx>0.166667</ixx>
        <iyy>0.166667</iyy>
        <izz>0.166667</izz>
        <mesh>
        </mesh>
        <mesh>
        </mesh>
      <surface>
        <friction>
          <ode>
            <mu>1</mu>
            <mu2>1</mu2>
            <slip1>0</slip1>
            <slip2>0</slip2>
          </ode>
          <torsional>
            <ode>
              <slip>0</slip>
            </ode>
          </torsional>
        </friction>
        <bounce>
        </bounce>
        <contact>
          <ode>
            <kp>1e+13</kp>
            <kd>1</kd>
          </ode>
          <bullet>
            <kp>1e+13</kp>
            <kd>1</kd>
          </bullet>
        </contact>
      </surface>
  <static>0</static>
<parent>rod</parent>
  <axis>
    <xyz>0 0 1</xyz>
    <limit>
      <effort>-1</effort>
    </limit>
    <dynamics>
    </dynamics>
  </axis>
  <physics>
    <ode>
      <limit>
        <cfm>0</cfm>
        <erp>0.2</erp>
      </limit>
      <suspension>
        <cfm>0</cfm>
        <erp>0.2</erp>
      </suspension>
    </ode>
  </physics>
  <axis>
    <xyz>0 0 1</xyz>
    <limit>
      <effort>1</effort>
    </limit>
    <dynamics>
    </dynamics>
  </axis>
  <physics>
    <ode>
      <limit>
        <cfm>0</cfm>
        <erp>0.8</erp>
      </limit>
      <suspension>
        <cfm>0</cfm>
        <erp>0.8</erp>
      </suspension>
    </ode>
  </physics>
<static>0</static>
