Gazebo no window appear
I've installed Gazebo from sources and now trying to launch it
$ gazebo
That's it! No window appear no matter how long I wait. All the files apper to be on their places. I can run this
$ gazebo -h
gazebo -- Run the Gazebo server and GUI.
gazebo [options] <world_file>
Gazebo server runs simulation and handles commandline options, starts a Master, runs World update and sensor generation loops. This also starts the Gazebo GUI client in a separate process.
Options: -v [ --version ] Output version information. --verbose Increase the messages written to the terminal. -h [ --help ] Produce this help message. -u [ --pause ] Start the server in a paused state. -e [ --physics ] arg Specify a physics engine (ode|bullet|dart|simbody). -p [ --play ] arg Play a log file. -r [ --record ] Record state data. --record_encoding arg (=zlib) Compression encoding format for log data (zlib|bz2|txt). --record_path arg Absolute path in which to store state data. --seed arg Start with a given random number seed. --iters arg Number of iterations to simulate. --minimal_comms Reduce the TCP/IP traffic output by gazebo. -g [ --gui-plugin ] arg Load a GUI plugin. -s [ --server-plugin ] arg Load a server plugin. -o [ --profile ] arg Physics preset profile name from the options in the world file.
So, the executable seems to be working. If I try to load the world
$ gazebo worlds/pioneer2dx.world
Still nothing. How can I determine what's wrong and fix it?
$ gazebo
gazebo $
$ gazebo -h
-h gazebo -- Run the Gazebo server and GUI.
gazebo GUI. `gazebo` [options] <world_file>
<world_file> Gazebo server runs simulation and handles commandline options, starts a Master, runs World update and sensor generation loops. This also starts the Gazebo GUI client in a separate process.
process. Options: -v [ --version ] Output version information. --verbose Increase the messages written to the terminal. -h [ --help ] Produce this help message. -u [ --pause ] Start the server in a paused state. -e [ --physics ] arg Specify a physics engine (ode|bullet|dart|simbody). -p [ --play ] arg Play a log file. -r [ --record ] Record state data. --record_encoding arg (=zlib) Compression encoding format for log data (zlib|bz2|txt). --record_path arg Absolute path in which to store state data. --seed arg Start with a given random number seed. --iters arg Number of iterations to simulate. --minimal_comms Reduce the TCP/IP traffic output by gazebo. -g [ --gui-plugin ] arg Load a GUI plugin. -s [ --server-plugin ] arg Load a server plugin. -o [ --profile ] arg Physics preset profile name from the options in the world file.
file.
worlds/pioneer2dx.world $
