error while publishing trajectory_msgs/jointtrajectory msgs
When i set the position and velocities of the joints in the trajectory msgs i got an error
[state_publisher-2] process has died [pid 13362, exit code -11, cmd /home/rob/catkin_ws/devel/lib/r2d2/state_publisher __name:=state_publisher __log:=/home/rob/.ros/log/9980f352-cf74-11e6-8644-d4c9efe8bd37/state_publisher-2.log].
log file: /home/rob/.ros/log/9980f352-cf74-11e6-8644-d4c9efe8bd37/state_publisher-2*.log
My ros node to send geometry_msgs is:
#include <string>
    #include <ros/ros.h>
    #include <sensor_msgs/JointState.h>
    #include <tf/transform_broadcaster.h>
    #include <trajectory_msgs/JointTrajectory.h>
    #include <vector>
    int main(int argc, char** argv) {
        ros::init(argc, argv, "state_publisher");
        ros::NodeHandle n;
        ros::Publisher joint_pub = n.advertise<trajectory_ms
gs::JointTrajectory>("set_joint_trajectory", 1);
   ros::Rate loop_rate(30);
   const double degree = M_PI/180;
   // robot state
   double tilt = 0, tinc = degree, swivel=0, angle=0, height=0, hinc=0.005;
   // message declarations
   trajectory_msgs::JointTrajectory joint_state;
   std::vector<trajectory_msgs::JointTrajectoryPoint> points_n(3);
   points_n[0].positions[0] = 1; points_n[0].velocities[0]=10;
   while (ros::ok()) {
   //update joint_state
   joint_state.header.stamp = ros::Time::now();
   joint_state.joint_names.resize(3);
   joint_state.points.resize(3);
   joint_state.joint_names[0] ="swivel";
   joint_state.points[0] = points_n[0];
   joint_state.joint_names[1] ="tilt";
   joint_state.points[1] = points_n[1];
      joint_state.joint_names[2] ="periscope";
       joint_state.points[2] = points_n[2];
       joint_pub.publish(joint_state);
       // This will adjust as needed per iteration
       loop_rate.sleep();
   return 0;
Here when i donot set the position and velocity value it runs without error and when i run rostopic echo /set_joint_trajectory i can clearly see the outputs as all the parameters of points is 0.
#include <string>
    #include <vector>
        ros::NodeHandle n;
   // robot state
   while (ros::ok()) {
       loop_rate.sleep();
   return 0;
Here when i donot set the position and velocity value it runs without error and when i run rostopic echo /set_joint_trajectory i can clearly see the outputs as all the parameters of points is 0.0. I also tried below program but it is publishing nothing:
  #include <string>
    #include <vector>
        ros::NodeHandle n;
        ros::Publisher joint_pub = n.advertise<trajectory_msgs::JointTrajectory>("set_joint_trajectory", 1);
           joint_state.header.frame_id = "camera_link";
           size_t size = 2;
           for(size_t i=0;i<=size;i++) {
              trajectory_msgs::JointTrajectoryPoint points_n;
              int j = i%3;
              points_n.positions.push_back(j);
              points_n.positions.push_back(j+1);
              points_n.positions.push_back(j*2);
              joint_state.points.push_back(points_n);
              joint_state.points[i].time_from_start = ros::Duration(0.01);
           ros::spinOnce();
       return 0;
