Can't attach plugin with roslaunch
My world file (adapted from the tutorial) contains a plugin :
<model name="my_car">
        <uri>model://car</uri>
    <plugin name="car_control" filename="car_plugin/build/libcar_plugin.so">
        <velocity>2</velocity>
The plugin loads and displays the expected message when I do this :
$ export GAZEBO_MODEL_PATH="$CATKIN_WS/src/tas_group_2/car_gazebo/models"
$ export GAZEBO_PLUGIN_PATH="$CATKIN_WS/src/tas_group_2/car_gazebo/plugins/"
$ gazebo worlds/car.world
However I can't get it to launch through roslaunch with :
$ roslaunch car_gazebo car.launch
Gazebo displays no error and the simulation seems to run. The problem is the plugin doesn't seem to run.
My files contain : package.xml (car_gazebo) :
<?xml version="1.0"?>
<package>
    <name>car_gazebo</name>
    <run_depend>gazebo_ros</run_depend>
    <build_depend>gazebo_ros</build_depend>
    <buildtool_depend>catkin</buildtool_depend>
    <export>
        <gazebo_ros gazebo_model_path="${prefix}/models"/>
        <gazebo_ros gazebo_plugin_path="${prefix}/plugins"/>
    </export>
</package>
car.launch :
<launch>
    <arg name="world_name" value="$(find car_gazebo)/worlds/car.world" />
</launch>
I thought the two methods where equivalent. Any idea how to get the plugin to work with the roslaunch command?
Cheers
<package>
    <export>
    </export>
</package>
car.launch :
<launch>
</launch>
Cheers
Can't attach load plugin with roslaunch
Gazebo displays no and I get te following error and the simulation seems :
[Err] [Plugin.hh:165] Failed to run. The problem is the plugin doesn't seem to run.
load plugin car_plugin/build/libcar_plugin.so: car_plugin/build/libcar_plugin.so: cannot open shared object file: No such file or directory
<package>
    <export>
    </export>
</package>
car.launch :
<launch>
    <arg name="verbose" value="true" />
</launch>
Cheers
Can't load plugin with roslaunch
What works
What doesn't
and I get te following error :
[Err] [Plugin.hh:165] Failed to load plugin car_plugin/build/libcar_plugin.so: car_plugin/build/libcar_plugin.so: cannot open shared object file: No such file or directory
<package>
    <export>
    </export>
</package>
car.launch :
<launch>
</launch>
Cheers
What works
What doesn't
<package>
    <export>
    </export>
</package>
car.launch :
<launch>
</launch>
I thought the two methods where equivalent. Because I specified the environment variables in the <export> tag.
Cheers
What works
What doesn't
<package>
    <export>
    </export>
</package>
car.launch :
<launch>
</launch>
Cheers
What works
What doesn't
<package>
    <export>
    </export>
</package>
car.launch :
<launch>
</launch>
I thought the two methods where equivalent. Because I specified the environment variables in the <export> tag.tag. It actually allowed gazebo to find my model, but not my plugin. How come?
Cheers
What works
What doesn't
<package>
    <export>
    </export>
</package>
car.launch :
<launch>
</launch>
My question
I thought the two methods where equivalent. Because I specified the environment variables in the <export> tag. It actually tag.
<gazebo_ros gazebo_model_path="${prefix}/models"/> allowed gazebo to find my model, but not while <gazebo_ros gazebo_plugin_path="${prefix}/plugins"/> doesn't help find my plugin. How come?
Cheers
What works
GAZEBO_PLUGIN_PATH="$CATKIN_WS/src/tas_group_2/car_gazebo/plugins"
What doesn't
<package>
    <export>
    </export>
</package>
car.launch :
<launch>
</launch>
My question
<gazebo_ros gazebo_model_path="${prefix}/models"/> allowed gazebo to find my model, while <gazebo_ros gazebo_plugin_path="${prefix}/plugins"/> doesn't help find my plugin. How come?
Cheers
