Why can't I set PID gains through JointController?
When I set the gains of my PID object using a direct reference it works, as :
common::PID pid = common::PID(0.1, 0, 0);
std::cout << pid.GetPGain();
pid.SetPGain(0.5);
produces
0.1
0.5
However, when I access it through the joint controller, the gain value isn't set.
std::cout << model->GetJointController()->GetPositionPIDs()[joint->GetScopedName()]->GetPGain();
model->GetJointController()->GetPositionPIDs()[joint->GetScopedName()]->SetPGain(0.5);
produces
0.1
0.1
Does GetPositionPIDs not provide you with the actual PID objects, but a bunch of copies?
Cheers,
