Gazebo crashes on Mac when model with CameraPlugin removed from scene
Gazebo crashes when I add and then remove from scene model with CameraPlugin. Tested with gazebo_ros_camera plugin.
Crashes happened even when I used empty plugin inherited from CameraPlugin with Load method calling parental CameraPlugin::Load(_parent, _sdf);. There is no crashed if there is no call parental CameraPlugin::Load(_parent, _sdf); in Load method.
Crashes appears on Mac OS X 10.11 + Gazebo 7.3 + ROS Jade and on Mac OS 10.12 + Gazebo 8 + ROS Kinetic Kane. Works fine on Ubuntu + Gazebo 7 + ROS Kinetic Kane.
Crash log:
/Users/Polonium/Documents/Projects/ros_jade/install_isolated/lib/gazebo_ros/gzserver: line 37: 2264 Segmentation fault: 11 GAZEBO_MASTER_URI="$desired_master_uri" gzserver $final [gazebo-2] process has died [pid 2200, exit code 139, cmd /Users/Polonium/Documents/Projects/ros_jade/install_isolated/lib/gazebo_ros/gzserver --verbose -e ode /Users/Polonium/Documents/Projects/somatic_ws/src/somatic_vehicle/media/worlds/somatic/hunters_point_demo_1.world __name:=gazebo __log:=/Users/Polonium/.ros/log/8e21cb4f-202d-11e7-a03d-7831c1bef192/gazebo-2.log]. log file: /Users/Polonium/.ros/log/8e21cb4f-202d-11e7-a03d-7831c1bef192/gazebo-2*.log
Crashes happened even when I used empty plugin inherited from CameraPlugin with Load method calling parental calling base CameraPlugin::Load(_parent, _sdf);. There is no crashed if there is no call parental base CameraPlugin::Load(_parent, _sdf); in Load method.
Crash log:
click to hide/show revision 3
None
Crashes happened even when I used empty plugin inherited from CameraPlugin with Load method calling base CameraPlugin::Load(_parent, _sdf);. There is no crashed if there is no call base CameraPlugin::Load(_parent, _sdf); in Load method.
Crash log:
Crashes happened even when I used empty plugin inherited from CameraPlugin with Load method calling base CameraPlugin::Load(_parent, _sdf);. There is no crashed crash if there is no call base CameraPlugin::Load(_parent, _sdf); in Load method.
Crash log:
