Hello. I'd like to contribute to gazebo_experimental, and have successfully built everything from source on a clean Ubuntu 16.04 desktop. I followed this tutorial to build all dependencies from source (in debug mode). Then I followed instructions here to attempt to build (in debug mode) and run. The build was clean, and all tests pass. But when I run gazebo -v 4
, I get the following errors:
[GUI] [Msg] Init app
[GUI] [Err] [PluginLoader.cc:89] Library[] does not exist!
[GUI] [Err] [Iface.cc:244] Failed to load plugin [gazeboGuiDisplayImage]
[GUI] [Err] [Iface.cc:244] Failed to load plugin [gazeboGuiDiagnostics]
[GUI] [Msg] Create main window
[GUI] [Msg] Run main window
QMetaObject::invokeMethod: No such method QMenuBar::aboutToShow()
My ENV variables are set as follows:
vagrant@vagrant:~/dev/gazebo/gazebo_experimental/build$ echo $LD_LIBRARY_PATH
/usr/local/lib
vagrant@vagrant:~/dev/gazebo/gazebo_experimental/build$ echo $GAZEBO_PLUGIN_PATH
/usr/local/lib:examples/dummy_demo/systems/
Any help would be appreciated.
