Wheeled models slowly roll when not being driven
Wheeled models have a tendency to slowly roll when not subject to any other force (i.e. by a plugin driving the wheels). I have noticed this with both a URDF Segway-with-casters model and a URDF quad wheeler. I assume the problem is due to noise when calculating contact between the wheels and the ground.
I just worked-around the problem in a diff-drive plugin (based on the ROS erratic diff-drive plugin) in the same way DRC pins joints: When the wheel velocity is set to zero, I zero the wheel joint velocity then insert a static link between the wheel and the world, then remove it when before setting the wheel joint velocity to non-zero.
However this feels like a nasty kluge. Is there any better way of doing it? I was hoping for a model::Joint::setStatic(bool) method or something, but can't seem to find anything like that.
