From Mesh, into MeshManager, via SDF to a model in a world: how?
Howdy folks,
I am trying to get to the bottom of how exactly a mesh is loaded in Gazebo.
I am working on a Gazebo Plugin that generates trees procedurally such that I can create a forest where each tree's geometry/shape is unique (more or less).
I have figured out how to convert a procedurally generated tree to a Mesh, and then add this Mesh to MeshManager:
gazebo::common::Mesh * treeMesh = procTreeFunction();
treeMesh->SetName("Tree_1234");
gazebo::common::MeshManager::Instance()->AddMesh(treeMesh);
But what I am currently struggling with what to do next in order to see this tree in my Gazebo world, and what follows is questionable and is what I need some help with.
So next I am creating an SDF model string:
modelStr << "<sdf version='" << SDF_VERSION << "'>"
  "<model name='" Tree_1234 "'>"
  "<pose>" << pose << "</pose>"
  "<link name='link'>"
    "<velocity_decay>"
      "<linear>0.01</linear>"
      "<angular>0.01</angular>"
    "</velocity_decay>"
    "<inertial><mass>" << _mass << "</mass>"
      "<inertia>"
      "<ixx>" << Ixx << "</ixx>"
      "<iyy>" << Iyy << "</iyy>"
      "<izz>" << Izz << "</izz>"
      "<ixy>" << 0.0 << "</ixy>"
      "<ixz>" << 0.0 << "</ixz>"
      "<iyz>" << 0.0 << "</iyz>"
      "</inertia>"
    "</inertial>"
    "<collision name='collision'>"
      "<geometry>"
        "<mesh>"
          "<uri>" Tree_1234 "</uri>"
        "</mesh>"
      "</geometry>"
    "</collision>"
    "<visual name='visual'>"
      "<geometry>"
        "<mesh>"
        "</mesh>"
      "</geometry>"
        "<material>"
           "<ambient>"  << _materialAmbient[0]  << " " << _materialAmbient[1]  << " " << _materialAmbient[2]  << " " << _materialAmbient[3] <<"</ambient>"
           "<diffuse>"  << _materialDiffuse[0]  << " " << _materialDiffuse[1]  << " " << _materialDiffuse[2]  << " " << _materialDiffuse[3] <<"</diffuse>"
           "<specular>" << _materialSpecular[0] << " " << _materialSpecular[1] << " " << _materialSpecular[2] << " " << _materialSpecular[3] <<"</specular>"
          "<emissive>"  << _materialEmissive[0] << " " << _materialEmissive[1] << " " << _materialEmissive[2] << " " << _materialEmissive[3] <<"</emissive>"
        "</material>"
    "</visual>"
  "</link>"
"</model>"
"</sdf>";
And then I add the model to my world
sdf::SDF sdfDescription.SetFromString(modelStr.str());
_parent->InsertModelSDF(sdfDescription);
However, instead of seeing a tree, I am seeing a cube (that appears to be a unit cube of 1 m^3). The cuboid is rendered in the correct material settings and at the right location. It's just not a tree :)
Does anyone have an idea what I might be doing wrong?
Thanks in advance!!
Galto
